Logik tv model L19LDVB11A WONT RETUNE IN NEW HOUSE USING AN ALL FOR ONE INDOOR DIGITAL AERIAL
GETTING RADIO IT SAYS IT PICKING UP CHANNELS BUT NO PICTURE
4 Suggested Answers
JomasTech
  • 66 Answers
SOURCE: We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Posted on Oct 17, 2009
  • 458 Answers
SOURCE: I have just moved house to Reading and previously
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Posted on Nov 15, 2009
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Posted on Dec 06, 2009
I bought aRCA air ultra thin multi directional indoor HDTV antenna,I cant get this to work with my tv, a 32mf330b/f7 no matter what I do no matter how many times I run the autoprogram,can You help.
Indoor aerials are exclusively for areas with a strong signal and the way digital tv works a good signal is essential.
I expect the signal where the aerial is sited has a poor signal strength and a high gain outdoor aerial will be needed. I suggest you have a look around and check what the neighbours are doing but bear in mind the signal strength in built up and fringe areas can be the radio equivalent of micro climates where moving a few yards in any direction and you could either be freezing or growing pineapples.
If you can take your tv to a good aerial and do a retune and store the found channels you might be lucky and discover your indoor aerial might receive a few channels well enough for viewing.
Mar 19, 2017 | Ultra Televison & Video
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
My 32inch Murphy LCD TV can not find the new
This could be a problem to do with your aerial rather than the TV. However, your first action should be a "Factory Defuault" reset. Make sure the TV does a full retune rather than just looking at the channels where the stations were previously.
The TV will have a flat response through the channel frequency range. Your aerial though could be a very different matter. Depending on the type of aerial, and especially if it's a banded aerial that discriminates against certain frequencies, then the retune may well have moved certain channel into frequencies that your current aerial really struggles to pick up.
You don't say what your TV region is, so I can't be specific because you didn't give the necessary information in the question. But I'll give you an example based on my region which is North West England, receiving off the Winter Hill transmitter.
Anyone with a Group C/D banded aerial will be okay picking up most of the channel muxes because they're grouped up at the top end of the frequency range (ch 49~57). That's pretty perfect for a C/D aerial. However, the new Freeview HD channels that give BBC 4 HD, 4 +1HD, BBC News HD is down at ch 37. A C/D aerial will struggle to pick that up because it is far less sensitive at that frequency, and particularly so if it is a contract Yagi type aerial.
The majority of aerials fitted though are the so-called Wideband High Gain. These favour the upper end of the frequency range again. So channel 37 will be picked up. But is is much weaker than the other muxes.
Sep 03, 2014 | Televison & Video
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
Oct 31, 2009 | Televison & Video
Oct 17, 2009 | Televison & Video
Cannot get any digital channels since local digital switch over
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Oct 05, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
After having to retune my Alba Freeview Digital Top Box - Model No. A002157058939 - on September 30th to allow for better digital reception of Channel 5, I am no longer able to receive ITV3. Have retuned...
You may need a better aerial. Digital TV signals need good signals or you can't pick up the full range of channels. Broadcasters and others are tending to keep their mouths shut about the expense of needing much better things on the roof than what many people use to get away with on analog signals. Even if you have a good aerial, If you have the 'brown' coax cable connected to it you could lose signal and stations. So it's best to replace it with Satellite coax cable FT100. That should stop a lot of blocking caused by interfearance by cars or those off road bikes youths ride around on.
Oct 04, 2009 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
