Question about Ricoh Aficio 2027 Black and White Copier
Reset drum ricoh 2027 - Ricoh Aficio 2027 Black and White Copier
5 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: ricoh 2027 sc792 erorr code
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
Posted on May 26, 2008
SOURCE: RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Posted on Oct 21, 2009
SOURCE: have ricoh 2027 - printer error code sc542 - how
ves revisa el tesmistor, el fusible que esta al lado hizquierdo del tesrmistor o si no pruba la continuidad de la lampara fusora que puede estar abierta despues de esto entra al modo de servicio, engine, luego al punto 5.mode despues con las flechas de arriba abajo localiza sc reset le das enter, prendes y apagas y problema solucionado espero te allude esa fue mi solución y te cuento que esta trabajando la lampara fusora estaba abierta.
Posted on Jul 24, 2010
santosj27
  • 263 Answers
SOURCE: connecting printer to network ricoh
Hello!
2027MP? Where did you saw that??
Go to this web page www.ricoh-support.com and you will find your machine model to free download the drivers.santosj27_2.jpg
Posted on Aug 11, 2011
Testimonial: "Thank you so much. Apologies typo should be SP instead"
RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND RESET SC CODES BUT STILL DOESNT WORK. HAVENT COME ACROSS THIS BEFORE.I KNOW ITS TD SENSOR FAULT, CHANGED WITH ANOTHER 2ND HAND UNIT I KNOW WAS WORKING FINE...
seal of the PCU
Good luck...
Oct 12, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
User Manual
hi
u can download manuals from the below link
PDF file
http://www.ricoh-usa.com/downloads/manuals/bw/aficio2022-27.pdf
Jun 18, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
RICOH 2027 SC792 ERORR CODE
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio 2027 Black and White Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
