Question about Casio Parts Cash Register PC Desktop
My cash button is not working - Casio Parts Cash Register PC Desktop
My ER-180T won't tender a cash sale. It just reads E13 when I hit cash/tender button. How do I fix?
Try pressing subtotal button first. If that doesn't work, try pressing subtotal then enter the amount on the display - but no decimal point - then press cash
Mar 31, 2017 | Retail Supplies
Tip
End of day reports (Z) for cash registers
SHARP
Most simple machines:
Turn key to Z or Z/P mode.
Press decimal point button
Press TL (your CASH button)
Most mid to high end machines:
Turn key to Z mode.
Type 100
Press X (next to decimal point). In USA, this button is called @/FOR
CASIO
Most machines:
Turn key to Z mode.
Press CASH
SAMSUNG
Most machines:
Turn key to Z mode.
Press 1
Press SUBTOTAL
OMRON
Older machines such as RS3010 and 3460:
Turn key to Z mode.
press 00 (double zero button)
Press X/Z button
If your brand is not listed, or these codes don't work, feel free to post a question in the forum.
Mark
on Jun 30, 2008 | Casio Parts Cash Register PC Desktop
PCR-T500 shows the E037, Digit or amount limitation over when I press the CA/AMT TEND, where I receive the cash and try to give the change to my customer, it is work when I PRESS CR and CHK, but it show...
It happens when someone accidentally re-programs the cash button while trying to change prices because they are not following the pricing instructions correctly. Try programming the cash button as a zero price. Do it just like you are making a price change but enter zero into the cash button instead of an item.
For those who have asked about a programming manual for the PCRT500, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T500_PCR-T520_Operation_and_programming_manual.html
Mar 28, 2015 | Retail Supplies
MA TEC-1450 numeric keys work but will not register when cash button hit??
Hi Chris.
You need to use a department or PLU (depending upon your setup) to register a product before you press the cash button. Check whether the machine registers when you use a product button. If so, you should try another payment button such as CREDIT. If it works, there is a problem with the CASH button programming
Dec 29, 2013 | Casio Parts Cash Register PC Desktop
Cash buttons don't work
Reset the machine (initial clear) reprogram again. good luck
Nov 06, 2013 | Casio TE-2400 Electronic Cash Register
My Casio PCR T480 will not work when the CA/Amt Tender button is pressed. I have tried clearing a machine lock up, which does not work. I'm not sure what has caused the problem initially as the cashier...
Hi. This is usually caused by someone reprogramming the status of the cash button while they are changing prices.
Try this.
Turn key to program
Press 0
Press CASH
Press Subtotal
Press 3
Press SUBTOTAL
Press 0
Press CASH
Press SUBTOTAL
Jul 30, 2013 | Computers & Internet
NOT ASSIGNED CODE
NOT ASSIGNED means no cashier is signed on. Find the cashier number button, probably labeled CASH #. In REG mode, press CL to clear the error, then 1, then CASH #, and Cashier 1 will be assigned. The display will show -01- Go straight from here into your sale.
Some registers are set up to not show the cashier number on the display or receipt. If 1 CASH # doesn't work, try CASH #, 1, CASH #.
Most users don't track sales by cashiers, so they forget they even have the capability, and they forget how to use that CASH # key. If you press the CASH # button without entering a number, it will sign out the active cashier, and you'll get this NOT ASSIGNED error.
Jan 23, 2012 | Sharp XE-A402 Electronic Cash Register
I have tk1300 casio cash register. i have input my new tax rate and now it ring up right tax with product, but only work when i used credit card button(CH) and it print and open the cash drawer. It beeps...
It sounds like you have programmed the CASH button. Try this:
Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL Turn key back to REG and try it.
If anyone is looking for a Casio TK-1300 manual, http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Jan 27, 2011 | Casio Parts Cash Register PC Desktop
I have a problem with cash button on TE 2400 cash register.
Hi.
Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Mark
Apr 11, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
26 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
