Question about Apogee Ensemble Audio Interface FireWire
Ensemble red light - Apogee Ensemble Audio Interface FireWire
At times during a performance the organ sounds drops significantly compared to the ensemble sounds, what could be the problem?
Has it always done that? It could be it just doesn't have enough power to play organ at full volume along side the ensemble.
May 25, 2015 | Roland VR-700 V-Combo 76 Key Stage Piano
How do I connect my Boss CE-5 pedal for stereo?
Quite simply connect each output to its own guitar amp or use two mono or one stereo DI box and connect to stereo PA.
Sep 25, 2014 | Roland Boss CE-5 Chorus Ensemble CE5...
Where would I go to get a back light for a Technics PR-305 Liquid crystal display
It could be the light, or it could be the inverter that powers the backlight. Try asking this guy: http://www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keyboard-ensemble-repairs/
Jun 09, 2014 | Universal MCU Extension 4 x 4 16-Key...
I am in a ukulele ensemble of 8. We all have electric pick ups in our ukes. what is the best way to connect to one amplifier, eg; using a mixer ?
It can plug into a guitar amp or PA system both. If you use an amp, you could hear yourself alone through that, then output jack "power amp out" to PA or put a mic in front of it from the PA. If you don't use an amp, it can plug into the PA but, you would only hear the 8 pieces together and have no way to hear yourself seperately.
Mar 29, 2014 | Music
On my fender blues deluxe, there is a red light which is usually off. I get intermittent loss of sound, and when this happens, the red light comes on. Any ideas what's wrong? Many thanks Brian
Hi.
If the red light is coming from a tube and you notice a loss of sound when it lights up, try reseating the tubes. You have to make sure that the amplifier is cool and is not plugged in to any power source when you do this and you have to be very very careful with the glass tube as well.
If the red light comes from an LED, it may be an indication of a bad wiring. Check if all wires are in good condition and are soldered correctly.
I hope this helps. Thanks. :-)
Apr 28, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I just bought a Deluxe VM .... when I plug it in, the red delay light is on....and everything has delay on it. When I press the little white button on the amp in or out, the red light on the amp still...
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Feb 25, 2011 | Fender Deluxe VM Tube Amplifier
I have a electone FC 20 all indicator lights are working and the ensemble section is working drum beat is ok its just the piano keys are not working could it be a fuse blown
Not likely iit is a fuse. The keys are likely scanned as a matrix with two contacts per key. You need to get a maintenance manual for thee organ. Contact Yamaha America parts for music products. They may have the service manual on CD... they used to get $15 for the CD of the manual. Unless you can find something simple like a cable knocked off this could be hard to troubleshoot.
Feb 24, 2011 | Yamaha Music
I need a manual for a Technics PR 350 Digital Ensemble Piano. Any idea where I can get one?
http://www.manualsonline.com/mdownloads/c1935b11-3977-438d-b81a-17c2101c2a7c.pdf
Aug 03, 2010 | Music
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Apogee Ensemble Audio Interface FireWire Logo
24 people viewed this question
Top Apogee Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Apogee Music Expert? Answer questions, earn points and help others
