Question about Maytag Neptune FAV6800AW Top Load Washer
PF display on my maytag neptune
My neptune started to fill with water and display reads PF and i can't find my manual to see what problem is- any thoughts?
I just got the PF error. It was due to some standing water on the floor because of some hard water build up in the hose connection filters. I guess this caused a short circuit and tripped the breaker. Once the hose filters were cleaned and the floor was dry, I was able to start it again.
Posted on Nov 18, 2007
I have the SAME problem! Everything seems fine when the door is open, but as soon as you close it - BAM! Power failure error comes on. It will also randomly turn itself on... not the washing cycle, but the display panel will light up and start beeping.
What would the pump section have to do with this?
Posted on Nov 08, 2007
  • 4,889 Answers
Hi liz PF on display means Power Failure...One of the components powering the machine is damaged...Do u know how to use a voltmeter?Do you have some knowledge abt electricals?IF YES report back..If not call a technician..You will need to check the power circuits around the motor section to see whats wrong..
Posted on Nov 03, 2007
  • eagle338
    eagle338 Nov 03, 2007
    You may also need to check the pump section..
2 Suggested Answers
  • 8 Answers
SOURCE: PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Posted on Mar 05, 2008
Maytag MD5500 displayed a code PF. what does that mean?
Power Failure maytag whirlpool same same:
Apr 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune dryer won't start. keeps trying and stopping. flashes PF on the display
neptune dryer has 8.8 on display and won't clear. How do you clear this?
Apr 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune Washer
Excellent, glad to hear we could help.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mar 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
224 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
