Question about Water Heaters
Junkers gas water heater ref wr275-6 kv1 b31 52895 fd085 keeps igniting itself and turning off
  • 34 Answers
SOURCE: Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Posted on Feb 08, 2009
  • 34 Answers
SOURCE: Junkers gas water heater automatic ignition not working
Yes that is going to be the contoll valve on that heater. You can probley fix it very easy with the right part. You will need to locate a plumbing supply over there in the UK. Give them the make and model number and tell them you need a unitroll gas valve for it.
Bati99
  • 88 Answers
SOURCE: Lighting Instructions for a Bosch Junker Water Heater
go to this site, have your model number at hand.
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/
Posted on Apr 18, 2009
  • 20 Answers
SOURCE: Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Posted on Mar 14, 2010
motor1258
  • 6674 Answers
SOURCE: the electronic ignition on a gas water heater will
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Posted on Jul 20, 2010
Still can't find where you light the pilot light for the hot water heater on a self igniting factory installed heater on a 1997 Pace Arrow.
Generally, if a RV water heater is self igniting, then it is not designed to be lit manually. If you remove the outside vent cover door, then the unit can be observed. The self igniter should be visible at a point of where the pilot light is located. The problem with trying to light the water heater manually is that the circuit that activates the igniter also turns on the gas at the same time. If the igniter is not getting power, then most likely the valve to turn on the gas is not getting power either. If the problem is that the igniter itself has failed, then it may be possible, but unlikely, that with someone inside activating the turn on switch and a flame being applied to the pilot light area, at the same time, the pilot may light.
Oct 04, 2015 | Water Water Heaters
Is the junkers WR 11 Gas water heater ok for outside mounting
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Dec 04, 2014 | Water Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers WR11 Water Heater Keeps Switching Off
Do NOT disconnect anything. Has the unit been maintained, cleaned and serviced? There may be a limit switch malfunctioning. Your safest bet is to have it checked out my someone who knows and is familiar with the unit you have, could be simple, but be safe and have it looked at.
May 27, 2014 | Water Heaters
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mar 02, 2010 | Water Heaters
Feb 08, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
