Question about Electronics - Others
What is the reason that 800 va microtek invertor sounding like tractor engine during charging
After power cut when power resumes and inverter start charging it sounds like tractor diesel engine with heavy vibration
I have a 24' travelaire 1989 rv. is there a switch to go from electrical hook up to battery operated lights in the camper
there is a power inverter,somewhere near the front of the trailer, RV Basics 12 Volt DC Systems
http://www.winnebagoind.com/resources/manuals/pdfs/Winnebago_Catalog.pdf
Atwood Mobile Products: 574-264-2131
Carefree of Colorado: 800-621-2617
Carriage Carpets (Shaw Flooring): 877-706-3054
CCI Controls: 800-521-5228
Coleman: 316-832-4357
Denso: call Fleetwood 800-322-8216
Dometic: 800-544-4881
Fantastic Vent: 800-521-0298
Generac: 888-GENERAC
Intellitec: 800-251-2408
Kidde Safety Products: 800-880-6788
Kwikee Products: 800-736-9961
Magic Chef 800-688-1120
Magnadyne: 800-638-3600
Norcold 800-543-1219
Onan: 800-888-6626
Power Gear: 800-334-471
Riverpark: 800-442-7717
Suburban: 423-775-2131
Suburban Dynatrail Furnace Manuals
Thetford: 800-521-3032
Velvac: 800-783-8871
Winegard: 800-288-8094
Xantrex (invertor/chargers and control panels )
http://www.rverscorner.com/wiring/index.html
Manuals 1989 older RVing The Midwest Connection
May 14, 2015 | Camper Vehicle Parts & Accessories
Can i use 150 am 12 va battery with 2000va microtek inverter
You can use any size you want, just your UPS can charge the battery.
You can also add an extra charger in special cases.
If your UPS calculates backup time, you need to tell how big the UPS batteries that you have ...
Aug 19, 2014 | Computers & Internet
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Can this equipment be used bidirectionslly? i.e.
you can use an invertor to power a battery charger to charge the boat battery but you could not use the invertor to charge the battery it was running from as the invertor will use power faster then the battery could be charged
Apr 05, 2010 | Vector MAXX 400 Watt Power Inverter -...
I have a Freedom invertor/charger 458 in my motorhome and i can't control the invertor with my remote board. I can push any button and nothing happens/no lights come on. it still charges and inverts. is...
Buy a long phone cord or however long youneed. Run it temporarily to the remote board and the invertor. Make sure powrr is off during this stage.If this doesn't work the solution is probaly going tobe much tougher. See manual.
Here is the owner's manual.http://www.donrowe.com/user_guides/xantrex/fdm_basic_remote.pdf
Feb 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Oct 02, 2009 | Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
