Question about Samsung Washing Machines
Samsung sw80usp wont drain - Samsung Washing Machines
  • 32 Answers
On my LG I removed the front panel and there was a drain trap with a filter. I removed and cleaned the filter. Mine started draining again. (assuming you have a front loader not a top loader)
Posted on May 07, 2014
Samsung washer wont drain
  • Check drainage pump filter for debris
  • Check drain hose and waste connection for kinks and blockage
Select a spin cycle to drain remaining water. If problem remains, service may be necessary.
Aug 04, 2016 | Samsung Platinum Front Load Washer -...
Samsung washer wa5451an wont drain
Had a similar problem. Turned out the pump impeller got jammed in a broken off zipper pull tab. The pump motor still ran and the belt was slipping. If you decect a burned rubber odour, then that is your problem.
J.I.
Mar 14, 2014 | Samsung WF337AA Front Load Washer
Hot water washing
You need to replace the water inlet valve.
Nov 10, 2012 | Washing Machines
My samsung sw80usp does not stop filling with water, no matter where i set the water level
Hi.
Make sure that at start the machine is filling, and that the noise you hear is not because of a broken inlet or because drain pump started at the beginning of the cycle after detecting water in the tub.
If the water does not stop filling and ends up with overfilling, then the pressure switch is usually responsible. Before going for pressure switch have a look at the inlet valve. Make sure that it is not stuck open. The pressure switch is accessed from top of the machine. It looks like a round shaped part with contacts at one side and a long thin rubber hose connected. The hose goes inside the tub. Clean pressure hose first. If that does not work replace the switch. If switch replacement does not work and inlet valve is OK, then control module is defective.
Regards.
Ginko
Sep 18, 2011 | Washing Machines
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
May 31, 2010 | Samsung WF337AA Front Load Washer
NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Aug 24, 2008 | Washing Machines
Washing Machines Logo
82 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
