Question about Microwave Ovens
Nn-c855 microwave/convection oven suddenly started beeping and showing beef/pork in the middle of the night, can't reset it
Tried pressing reset which stops the beeping and the words showing, but no other buttons will work. The display just shows a : and it doesn't matter what I press nothing works. Tried unplugging it for a few days but as soon as I plug it back in it goes straight back to beeping and showing beef/pork in the display
MicrowaveSvc
  • 9047 Answers
SOURCE: keypad on microwave wont work
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
eagle338
  • 4889 Answers
SOURCE: Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Posted on Sep 02, 2008
SOURCE: panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Posted on Jan 01, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: My microwave won't turn on
I would try another rest buy unplugging ti for a couple of minute,s then plugging it back in.
If it still fails, the keypad may be failing.
Sometimes this is due to direct spraying of cleaner on the controls, or steam or grease.
In models like this, disassembly and cleaning is required.
We can do that for you if you like.
Posted on Feb 10, 2010
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
I got this microwave in my house, but its not working. all the buttons are not working accept stop/cancel button. please send me the sollution.
I have a similar microwave that I recently repaired. NN-9854 (bad capacitor). So your microwave functions but you cant stop it unless you unplug it, it ends its cycle, or you open the door? Does it beep when pressed? If not, you need a new control pad.
Dec 19, 2009 | Panasonic NN-T888S Convection/Microwave...
Panasonic NN-H503B. Now some years old. Switched it on at the plug this morning and it did the following: constant peep, peep, peep, accompanied by the display flashing 9/Beef 10/Pork, 9/Beef 10/Pork...
It sounds like you have a shorted pad ("defrost", maybe?) on the keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Dec 12, 2008 | Microwave Ovens
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
Microwave NN V622m locked
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Mar 26, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
