Question about Electrolux Ovens
How to solve repeated F02 error 20 mins in to pyro clean on Electrolux EOEM61CS
Every time get F02 error about 20 mins into pyroclean function on Electrolux oven EOEM61CS
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
SOURCE: pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Posted on Aug 20, 2008
  • 905 Answers
SOURCE: I have an electrolux icon
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Posted on Dec 24, 2008
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Oct 05, 2017 | Viking Ovens
Getting f 68 fault code electrolux oven
Hey karl miller, I appreciate your inquiry!
From the information you have provided Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. This is not a simple DIY job. If you need additional assistance I would recommend contacting a professional technician for proper repair or replacement of electronic components. Hope this helps! -Matt
Feb 13, 2015 | Electrolux Ovens
Why my ew30ew55gs5 have no heat and all the light and function work.
Electrolux Customer Phone Number Shortest Wait Best Support
  • Talk to a Human Press 2 then 1. For kitchen and laundry appliances
  • Call Time
    Average Wait: 37 mins - Monday-Saturday, 8AM-9PM (EST)
Electrolux Calls You Instead Electrolux Calls You Instead
I would contact them first before you waste any money.
Jan 21, 2015 | Electrolux 30" Built-In Single Electric...
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
How to I clean the inner glass on a die dietrich pyroclean oven
If you are in the U/K, then go too the following site for a detailed explanation.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR GLASS
You should find a video showing you how to do it
Nov 30, 2010 | Ovens
Heated oven to 200 and on putting food in the oven there was a bright white light and a bit of smoke. I turned off and left for 20 mins and tried again and would not heat up properly. Has my element burnt...
that was your element burning out. you can change it from inside the oven but be carefull not to lose the wires. if you do you have to take the oven out to reconnect them
Aug 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
20 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
