Question about Konica Minolta Office Equipment & Supplies
Konica 6000 service mode - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Metercount then stop00 stop 01
Posted on Dec 30, 2015
What is the default input password (service password) for bizhub 554e printer.
9272 four times.
Service Mode password for new series Konica Minolta Bizhub series is "9272927292729272."
Dec 20, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub Pro C 6000 L. What does error Code C 3505 indicate?
Fusing high temperature abnormality The temperature sensor /1 (TH1) detects 150 °C or higher value continuously for a specified period of time.
Reset attempt once if the code comes back call a KMBS Tech
1. Be sure that the ordinary operation screen is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
select 03 System Setting
• 01 Software DIPSW Setting
Be sure to set the DIPSW3-1 to 0 after replacing the defective parts. If DIPSW3-1 is set to 0 before defective parts are fixed, it
may cause fire. DO NOT RESET MORE THEN ONCE COULD CATCH ON FIRE AT WILL RUIN A PERFECTLY GOOD DAY
To exit:
Service Mode menu screen"
Press [Exit] to back to "Utility screen".
2. The new settings become effective
Nov 20, 2015 | Konica Minolta Office Equipment & Supplies
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
I forget service mode password in konica minolta bh 501 can you help me
There is only 3 service mode password the easiest way to find it try the 2 and the other 1 tomorrow so it will not lock. 1) 11111111 2) 00000000 the last 3) 12345678. You dont have to go to [Utility] ... etc its a long process w/c you can see the service mode password/ change.
Nov 23, 2014 | Konica Minolta Office Equipment & Supplies
How can i enter the service mode for konica minolta bizhurb 250/350 black an white copier and how to adjust ATDC and to run f8?
To enter service: utility/counter, counter details, stop, 0, stop, 0, 1, then 00000000. F8 is found under functions menu. ATDC is run by F8.
Aug 11, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Service mode konica minolta bizhub C224e
Utility-stop-00-stop 01 press enter press 00000000 enter end
May 28, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c451 service mode password reset
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Mar 14, 2014 | Konica Minolta Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
