Question about Fisher and Paykel Dishwashers
Remove handle assembly from fisher paykel DD606
SOURCE: lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Posted on Apr 24, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 215 Answers
SOURCE: I have a fisher and paykel E522B refridgerator and
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Posted on Dec 13, 2009
Testimonial: "I actually found little hex screws at the bottom of each of the handles. Once both are loosened a fair way the handle comes off allowing tightening."
SOURCE: Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
Remove drawer from fisher-paykel dishwasher
Open the drawer.
Top tub : depress the right hand tub clip and push it back about 30mm. Repeat for the left hand side.
Bottom tub:
remove the toe kick (refer section 9.4) and lower tub cowling (refer section 9.5), both optional.
1. If the cowling has not been removed, then the tub clips need to be pushed back about 130mm so the slide clears the cowling when the tub is lifted.
2. Lift the tub off the slides and push the runners back into the product.
3. Releasing the wire from the centre clip on the link assembly allows the tub to be moved further from the chassis (optional).
4. If the tub is being turned over for servicing, rotate it counter clockwise, remembering to remove the baskets first. Removing the handle will prevent it from being damaged.
5. Refit in reverse manner.
May 09, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
How do i replace a fisher & paykel dw691ed ss handle
Refer this parts diagram.
http://spares.bigwarehouse.com.au/images/files/18196_71ac2010b1b67e91c23c267b28e0cae7.pdf
You have to remove the screws holding the front panel and access the door handle to replace it. Make sure the mains power chord is taken out from the plug.
Dec 14, 2013 | Fisher and Paykel Dishwashers
How do I replace handle/plastic cover on Fisher and Paykel soft touch 913t dishwasher?
Not sure if you have tried to refer to the parts manual itself which shows how the parts are assembled together. In particular page 8 which shows the handle assembly part 18. I am assuming this is what you are replacing. Or is it just part 21 which is the plastic latch recess cover.
Mar 21, 2013 | Fisher and Paykel Dishwashers
Fisher & Paykel DD24DT Dish Drawer Dishwasher. Handle is broken. Need to know if I can purchase a handle assembly, if so any idea on a Part number?
Michael,
Part number I came up with was a 522898, this handle comes in black, I assume this would be correct for the particle model number you gave here. I hope this helps, Fisher and Paykel number 888-936-7872 and they can send you the parts you seek directly. You will need to have the complete model nmber to order from them. Good luck.
Oct 28, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i change the handle on the double drawer fisher paykel dishwasher
You will have to get the front cover out by unfastening the large plastic tags on each side.
Be careful not to drop the front cover as the handle and display will fall down. Taken it out slowly and carefully. The handle will come off as soon as the front cover is taken off.
I am assuming you have already purhcased the new handle assembly.
Put in back in reverse order after you replace the handle.
Please rate this solution if you are satisfied otherwise post a comment.
May 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
