How to update aftron LED TV
I need to update aftron tv led software
SOURCE: 42pf7321d/37 phillips plasma tv
http://www.avsforum.com/avs-vb/showthread.php?p=16476036#post16476036 go to this web site and read what Shooterz posted about changing c8059 and c8060 on the power supply pwb. It worked on my TV. I'm neefly look at my post to buy caps online.
Posted on May 17, 2009
pilot210
  • 39 Answers
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Posted on May 19, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
  • 63 Answers
SOURCE: We just bought a devant
due to marketing and studies these companies are under the assumption that everyone that purchases a new tv is also buying a surround sound system. to cut cost they and save weight they go with lighter speakers. and then there is the this thing with loud sounds being the cause of people going deaf so to prevent that the manufacturer of your tv sets the decibels to an acceptable level because they care.even a tv from the eighties sounds better than most tvs today
Posted on Feb 22, 2011
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
My Sony Bravia TV will not turn on. the power light flashes red 7 times then stops for 4 seconds then repeats
System Error:
  • If a Red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most Red LED blink conditions require service. The meaning of the blink codes differs between TV models, but the following steps may resolve user serviceable errors related to heat, temporary conditions, or software updates:
    NOTE: 8 Times Blink - For certain models, a special reset procedure is needed if the Red LED on the front of the TV is blinking 8 times and then repeats. This is a model-specific issue that may be resolved by following these steps (please check the answer to be sure your model is included).
    For other TV models or other Red LED blink codes:
    1. Turn the TV off and back on. If the TV will not respond to the remote or the power button, or if that does not fix the issue, unplug the TV. For a Projection TV or Projector , leave it off for 3 minutes. For other TVs leave it off for 1 minute. Plug the TV it back in and turn it on.
      NOTES:
        • If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
        • Projection TVs and projectors need to cool down before they will turn on again. You may need to wait several minutes before these will turn back on.
    2. Clean any vents/slots in the TV cabinet and make sure there is room for air to circulate around the cabinet of the TV.
    3. Some Sony TVs have a media box (tuner) and separate display. If you have one of these TVs, check to make sure the cable between the media box and the display is securely connected.
    4. For Projection TVs and Projectors, make sure that the cover/door for the lamp is closed and secure.
    5. If the TV can be operated at all, check to see if a software update is available.
      • If your TV is connected to the Internet, press the Home or Menu button on the remote to get into the setting menus. The Software Update option is usually found under theProduct Support or Contact Sony menu.
      • NOTE: For a limited number of Internet-capable models, the only option is to turn onAutomatic Software Updates and allow the TV to update on its own. If you only have this option, make sure it is set to On. Automatic updates are only downloaded when the TV is in standby mode (turned off with the remote but not unplugged). Normally this download will happen overnight but may take up to 24 hours.
      • Software and driver updates for your Sony product are available online. You can check to see if a software (firmware) update is available for your television. Steps to install will be included if an update is available.
      • Older CRT TV's and TV's that cannot be connected to the Internet do not have an option to check for a software update or may not capable of being updated.
  • If these options do not resolve the issue, the problem is most likely related to an internal component that must be replaced and service will be required.RF
Mar 04, 2015 | Sony BRAVIA Televison & Video
Aftron 32 led model af led 3200 only blue screen no display
Check the input selection. Select it to TV, and connect an external Ariel, and check. If there is no picture turnes in; the tuner to your TV is faulty. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 09, 2015 | Televison & Video
How to update (firmware) software in Videocon LED 32" DDB tv
how can i update the software of videocon led tv 32''
Sep 05, 2013 | Televison & Video
I can not get the power lights and standby lights to turn off even when i turn them off in the menu , the remote is sluggish, and if i turn tv on on the tv i get a long beep my tv is a 55 inch led lg...
First thing to try would be to update the firmware. This link should take you to the LG support site where you can find the download and instructions you need to update your television. Look under drivers and software. Good luck.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=55LE5500
Apr 28, 2011 | LG 55LE5500 55 in. HDTV LED
Need aftron lcd tv manual
my aftron tv has been locked by mistack.it is showing the locked symbol only.please help me
Dec 19, 2009 | Sharp R-510HW Microwave Oven
Televison & Video Logo
250 people viewed this question
Top Televison & Video Experts
Electro Med Services...
