I have canon irc3220n and the hhd is damage i manage to get a hdd from my desktop replace it and i have sst v4.11 i understand that canon hdd already have the bin file preinstalled mine dont have the bin file. How can i get the bin file and can i install it into my new hdd please help i understand that the bin file is the one which intiate the communication btwn the computer and copier when connected using a crossover cable
Jowinson
  • 16 Answers
SOURCE: Creating a Scan folder
In this case, make sure that your Canon Copier Imagerunner C587OU has CD software that comes with it. You need to connect the Canon copier to the computer with a USB cable or through the parallel port which the Canon Copier may not likely have. Then on your Pc and put the cd in the Cd drive of the Pc, when your Computer prompts "Found New Hard Ware" direct the computer to install the Canon copier through the Cd drive, after the Installation the Computer and the Canon copier can now be able to communicate thereby allowing you to scan from your Pc to the canon copier.
Posted on May 08, 2008
  • 93 Answers
SOURCE: how to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
Posted on May 26, 2008
ksdi
  • 34 Answers
SOURCE: CANON PIXMA MP 160,CAN'T SCAN
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
271
Posted on Mar 16, 2009
  • 199 Answers
SOURCE: ir400 copier HDD fomat and sytem softwear update Problem
it's formatting possible in few city only in india like MUMBAI - DELHI - INDORE etc. because it's not a common or general format process. Try nearest used copier dealer.
Posted on Jun 14, 2009
  • 89 Answers
SOURCE: ir5000i error 602
Ask Canon. If you're authorized they should be able to help you get what you need.
If you're not a tech get a tech to do it.
Posted on Jul 25, 2009
I'm having canon c5035i, after booting I had this code E000602-0912. What is the cause please?
Error in HDD
Description System error or Packet data error
Remedy It's due to data corruption or software bug.
1. Start in Safe Mode to perform overall format with SST and
reinstall the system (System, Lang, RUI), and then turn OFF
and then ON the Main Power Switch.
2. If the above measures do not solve the problem, it can be
caused by failure with the HDD; therefore, replace the HDD
and reinstall the system.
Dec 24, 2017 | Canon Office Equipment & Supplies
Hard disk is ok then occur code E602-0001
Canon? Naughty Canon.
There is no hdd compatibility list / HDFormat files are encrypted > not viewable
Originally these HDD Dewcriptor Files were regular text files which could be edited to add new HDD formats when
necessary. More recently Canon has started encrypting the files to prevent them being edited.
Modifying the HDD Descriptor is out of the question on this series
Canon ImageRUNNER's will require that authentic Canon HDD's be installed should they require replacement. Generic drives may not be on
the list of supported drives for the SST and Canon will not release a list of supported drives.
http://www.copytechnet.com/forums/canon/100500-e602-0001-a.html
Oct 26, 2015 | Computers & Internet
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Help formatting HDD and installing SST on Canon iR3300i
Hi
Formatting and installing sst must be done on a computer with Canon support tool
Dec 31, 2010 | Canon Office Equipment & Supplies
Won't print;
The problem means that your hard disk needs to be replaced. E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed. Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the hdd from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
Thank you !!
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the hdd and it will pup up ready to go.
Hope this helps.....
May 21, 2010 | Canon imageRUNNER 2800 Black and White...
Canon ir3300 error602-003
how to install data in the hardisk of ir 3300 machine. plz say me the full process what is sst and everything
Dec 09, 2009 | Canon Office Equipment & Supplies
E000602 0003
Bad sector read on hdd. Call tech to try to see if they can get the hdd to work or probably a better solution replace it and then reload firmware using sst.
Aug 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E602
You can get the canon SST by download from
here
You will still need to get the relevant system software for your model to register within the SST.
Jul 09, 2009 | Canon Office Equipment & Supplies
HDD
Get a technician to replace hdd, format and reload system software using sst.
Apr 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
Nov 23, 2006 | Canon imageRUNNER 8500 Copier
k24674
jasbo
jasbo
