Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
How to fit kit handle assembly on fisher paykel DD 606?
reg501
  • 413 Answers
SOURCE: fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Posted on Jun 08, 2008
  • 113 Answers
SOURCE: U2 Error Fisher Paykel dd-602 dishwasher
Hi there, Error U2 -
Possible Causes - Loading
Check loading to ensure no items extend
beyond the height of the drawer.
Good Luck!
neo
Posted on Feb 27, 2009
  • 864 Answers
SOURCE: where can i get a service manual for free fisher Paykel dd/ds602
Look at:
http://fisherpaykel.com/global/customer-care/product-manuals.cfm
I got no results using the model number you provided but you can contact Customer Service from that website.
Posted on Jun 30, 2009
  • 784 Answers
SOURCE: My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Posted on Sep 12, 2009
SOURCE: FISHER & PAYKEL DD-603
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Posted on Mar 30, 2010
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Fisher & Paykel DD24DT Dish Drawer Dishwasher. Handle is broken. Need to know if I can purchase a handle assembly, if so any idea on a Part number?
Michael,
Part number I came up with was a 522898, this handle comes in black, I assume this would be correct for the particle model number you gave here. I hope this helps, Fisher and Paykel number 888-936-7872 and they can send you the parts you seek directly. You will need to have the complete model nmber to order from them. Good luck.
Oct 28, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi ya. we have a fisher and paykel nautilus dishwasher. and it has a fault. f4 is on the panel. and its not draining water. help please
This means something wrong with the water heater.
Most likely you will need to replace it. It will look something list this.
Will need a technician to fix it if you are not very comfortable to handle such equipment.
Please rate this solution.
Aug 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Rotator arm is detached from gear
I am assuming the plastic wheel type device which moves the washer arm has come out.
I think you will have to buy the whole rotor assembly. Should cost around $50.
Go to page 17 of Parts Manual and check part no. 5 Rotor assembly.
I have seen it is available from Fisher and Paykel parts shop online. They are located in Milwaukee (ie, if you are in USA)>
Jun 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i change the handle on the double drawer fisher paykel dishwasher
You will have to get the front cover out by unfastening the large plastic tags on each side.
Be careful not to drop the front cover as the handle and display will fall down. Taken it out slowly and carefully. The handle will come off as soon as the front cover is taken off.
I am assuming you have already purhcased the new handle assembly.
Put in back in reverse order after you replace the handle.
Please rate this solution if you are satisfied otherwise post a comment.
May 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Where can i get a service manual for free fisher Paykel dd/ds602
Look at:
Jun 30, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
DD603SS DISHWASHER PROBLEM
This is simple you need a new Detergent dispenser fitted in the bottom drawer. cheers
Mar 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Oct 30, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
51 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
