Question about Building Materials
445r hormann How i reset the 445 R horman
I have a Hormann 5500 series. The door closes but automatically reopens when it touches the ground.
I do not know, but I guess that a "bad" handling of the machine during a move may have maligned parts.
This is only a guess.
Jun 28, 2017 | Washing Machines
ENG. LIGHT ON CODES PO 442 ANDPO 445 IS SHOWING UP ON SCANER
The PO 442 code is an EVAP system small leak, either in the evaporative system or cooling. Sometimes this will occur after a drenching rain and remain until the diagnosis code is reset, usually will disappear after you read the codes. If not, a dealer can reset the code system via the radio believe it or not. PO 445 is similar, an EVAP system code but is usually related to gas vapors being sent to the engine rather than through the atmospheric venting system. Check the gas cap system here first, a gas cap not properly tightened (3 click) will sometimes cause this. Also, look to the spark system wiring harness or purge control solenoid.
Sep 16, 2014 | 2001 Dodge Ram 1500 Truck 2WD
How to align camshaft and hormanic polly after timming belt broke
I will check for you......they are bent/ broken.
Sep 03, 2014 | 1999 Nissan Quest
Programming a Hormann HSE2-868 Remote Control
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 12, 2014 | Televison & Video
During installation, when I press large "t" button, door does NOT go through its four cycles
If this is an Horman opener unplug it so that the limits reset then plug in the opener and press the T button again and see if it goes through it's paces
Oct 19, 2013 | Building Materials
Hormann garage door
If the courtesy lights on the motor unit aren't turning on, there may be no power getting to the machine, or there may be a fault in the control board. If the opener is getting mains power, I would suggest calling a Hormann dealer.
Sep 17, 2013 | Building Materials
How do I reset hand held door opener for horman silent drive 5500 series
The instructions for programming are on page 34 of your owners manual. If you do not have the manual you can go here.
http://www.hormann.us/assets/1/Page/SilentDrive_TR10H004D_0710.pdf
May 12, 2012 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
100 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
