Question about Fortinet, Inc. FortiClient Host Securtity (fch) Firewall
Forticlient connect setup wizard ended prematurely
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
My 2wire product seems to need resetting every few minutes. As soon as it's unplugged and plugged back in, it works. However, after a few minutes, it loses connection again. Is this an issue with my ISP,...
  • Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
  • Re-run the HomePortal Setup Wizard from the HomePortal CD.
  • Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
  • (For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
If required, make sure that you are using your unique username and password. If the problem persists, contact your ISP to verify your connection type and login information (if necessary). After verifying your connection type, also verify that you are using the correct keycode by referring to your HomePortal documentation or by visiting http://www.2Wire.com/keycode.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
I was just in a chat session with Riztech and the chat ended prematurely
When a chat ends prematurely, it must be a problem with the network connection.
When the network is disconnected or when the speed slows down, the chat will be ended.
You can always check your network connection and your internet speed when this problem occurs.
Thank you for using Fixya,
Kenneth
Apr 23, 2010 | Computers & Internet
What websites are not blocked by forticlient
netgear has blocked zwinky.com
and i have not been on it for days and days
today me and my sis wanted to have 30min of zwinky
but i couldn't get because of netgear:(
Jan 16, 2010 | Fortinet, Inc. FortiClient Host Securtity...
Setup won't go through - error
I had a similar problem, and how I fixed it, was I made sure the connection was working, so the pc end had right details, and then I turned it off, and then put in router, and when it started back up, it started up and connected straight away.
May 31, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Printer hook up
With most printer setups - you will need a bi-directional cable (the one with the ends that are rectangular and have several "pins" with clips to secure one side to the printer and the other to the computer) - most default setups will run through LPT 1 (the port) through the auto setup wizard in windows (windows should also automatically recognize the drivers for installation). You should be able to connect one end of the cable to the printer, the other end to the back of the computer (the only connection that fits) and windows should guide you the rest of the way.
Feb 01, 2009 | Toshiba Satellite M35X-S163 Notebook
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
How do u connect the xbox360 to my computer
hi
) Run the Network Setup Wizard
2) Select the first option ("My computer is directly connected to the Internet") and click Next.
3) Select your Wireless Adapter and click Next
4) Select your LAN Network and click Next.
5) Wait for it to finish configuring the home network.
6) Select "finish the Wizard" and end the Wizard.
7) Restart the computer.
8) Connect to the Internet.
9) Try connecting to Xbox Live with your Xbox 360.
10) Success!!
Note: Make sure your connected with your Wireless Adapter and the Xbox 360 is connected to your LAN Network.
cheers!!!!
Feb 09, 2008 | Computers & Internet
Computers & Internet Logo
664 people viewed this question
Top Fortinet, Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Fortinet, Inc. Computer and Internet Expert? Answer questions, earn points and help others
