Question about Cell Phones
My firefly gt100 doesnt is always low bat even its in a charging state.i charge it for 3 hours and still in 2%.what to do?
joshy999
  • 241 Answers
SOURCE: LG KG800 charging problem.
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Posted on Jan 21, 2008
SOURCE: Sansa E250 Battery Low always when charged fully
throw the damn piece of ******* **** out the window
Posted on Apr 05, 2008
SOURCE: LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
Posted on May 18, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: i have a battery low problem after 1 or 2 hours
Dear friend,
i have same mobile nokia n73 me edition. It was same problem with me. The batter gives your 3 - 3 1/2 years good service if your use its like a breathing. hahaha. after that you need to replace it. try those of things like. low background light, minimize standyby time etc . but i dont think it working. When you pick up call you will see low battery or mobile off & again you restart you seen the battery fully charged. Dont thing that hand phone problem. ITs mean battery need replacement. THx
Posted on Jan 29, 2010
SOURCE: 'please wait, very low battery' but not charging
Try to reformat it. It might be a virus or a bug.
Posted on Apr 27, 2010
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
How do I know its fully charged?
It depends if the charger are intelligent or not, check the owners manual.sometimes changes, it depends the manufacturer charger.when it compares charges, disconect itself the circuit. not always.
Oct 18, 2014 | SoundLogic Sound Logic Power Cell...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Emerson emp287c-4 wont charge with usb
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
Dec 26, 2012 | Emerson Televison & Video
No charge to bat but runs ok for 2 weeks so far
Sounds like dead battery cell Have bat checked.It's not a good idea to disconnect the battery on a modern computer controled vehicle while the car is running.
Sep 16, 2009 | 2000 Cadillac DeVille
Phone doesnt charge....
Hello ! pls use the right charger for it using a different charger can damage the charging IC of the phone .
The charger for LG could look the same but designed different also the bat can be damaged thats means it won't charge
Get a new Bat then try what have told u
good day .
Aug 31, 2009 | LG Secret ? KF750 Cellular Phone
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Cell Phones Logo
65 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
