Question about Air Tools & Compressors
Ingersoll rand manual SSR M22 - Air Tools & Compressors
  • 89 Answers
SOURCE: Cant set my compressor to automatic start/stop mode
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
ollie reece
  • 1167 Answers
SOURCE: cuts off with no reason
hi mate when the reach there working pressure e.g.150psi/10bar they shut off and then when the pressure drops to a pressure of e.g. 100 psi 7 bar they automatically start back up and pump back upto they working temperature or if it dont start at all it could either be a faulty pressure switch or a fualty star delta starter if its 3 phase 415 volts if its 240volt there are only a pressure switch which will be faulty get a sparky in to sort it out there buggers to mess with 415volts 240 volts easy
Posted on Jul 08, 2009
SOURCE: Ingersoll Rand SSR-EP75 owners manual, I need to
The pulley is held on by a compression type of coupling. Loosen all the screws in the coupling. Remove two screws and they should thread into two or more threaded holes in the coupling. These are holes that should be 180 degrees apart....they will be the only holes threaded. If all the other bolts in the circumference are loose you should be able to thread these two bolts into the coupling and the bolts actually "jack" the coupling apart. The coupling and fan should easily come off the front of the motor. The motor should be held on by 4 screws to the motor tower in front of your air/oil cooler.
Posted on Sep 04, 2009
Testimonial: "Although the information is way late, it is accurate information"
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
Excessive oil with air
Replace the oil separator it should work or check the scavange line for blockage
Mar 28, 2014 | Ingersoll Rand Air Tools & Compressors
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Air Tools & Compressors Logo
88 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
