Question about HP LaserJet 4 plus Printer
Hoe to print acetate paper in Hp Printer - HP LaserJet 4 plus Printer
4 Suggested Answers
Wiired
  • 122 Answers
SOURCE: HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Posted on Jun 23, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
  • 103 Answers
SOURCE: HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Posted on Jul 28, 2010
Is it possible to use a Kyocera TASKalfa 300i to print on acetate?
Not unless you get LASER printer acetate. Otherwise it will melt on the fuser and cause a costly repair bill.
Printer Repair Service in Miami and Fort Lauderdale FL
May 05, 2016 | Kyocera Office Equipment & Supplies
Hoe kan ik mijn inkt niveau van printer Deskjet F380 op mijn laptop zien??? De printer zat vroeger aangesloten op een DELL met besturing voor XP. Maar ik heb nu een besturing op mijn laptop voor Windows 7...
I downloaded the User guide from HP http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&product=3390947
It gives very simple instructions for removing the rear access door (Follow the arrows beside the door and push the door to the right and pull out). I found a torn corner of crumpled paper in there. It also warns against pulling paper out the front which can damage the print mechanism.
Jan 22, 2014 | HP DeskJet F380 All-In-One Printer
Can I print onto acetate paper (clear sheets) with a brother 7440n printer?
Presumably you want to make transparencies. There are Transparencies available specifically for Laser printers and Copiers. Do not use anything else or they will melt around the fuser and wreck your machine. Fixable but expensive.
Oct 09, 2013 | Brother HL-2040 Laser Printer
How can I print on acetate, tried but acetate just comes out and printer asks me to feed paper
Nothing wrong with your printer! Most printers detect paper presence with a LED. Problem is acetate
being clear the printer thinks the source tray is empty. :)
* Go down to an office supply store and buy acetate that has a 1/4" strip of opaque material on the short
edge.
* DIY. Take some permanent marker and with a ruler put a black stripe on the short edge. Let it dry. That
should let the printer sense that acetate is there.
Mar 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
I have an epson SX200 could you please tell me what paper type I go on to print on acetate. I remain hopeful
This product does not support acetate or OHP printing due to the relative inexpensive cost associated with the device epson marketed this for Photo printing and general B-W colour prints only. it is not recommended to print on acetate or OHP film.
If this answered your question please rate the resolution accordingly
Regards
Sep 14, 2009 | Epson Office Equipment & Supplies
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP LaserJet 4 plus Printer Logo
77 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
