Question about Soleus KY-34 Portable Air Conditioner
Solebus heating my soleus ky-34 exhaust fan run while in heating mode.
  • 883 Answers
Re: solebus heating
Yes, it is intended that way. I also have a Soleus and a special manual addendum sheet was inside the manual and it pointed out this feature..I think Soleus had a lot of customer phone-ins over this...I guess the idea for the exhaust is to withdraw moisture from the room, since anytime air is heated or cooled, moisture is a by-product that must be eliminated.
Posted on Nov 04, 2007
0 characters
3 Points
Exhaust hose
I would try any plumbing/heating store.
May 14, 2014 | Soleus KY-34 Portable Air Conditioner
Has E4 showing on machine have turned off and on but still reads E4
  1. E-4 ..........short of as or no gas. Refill gas after leak testing.
Dec 14, 2010 | Soleus KY-34 Portable Air Conditioner
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Sunbeam KY-25 portable air conditioner not working.
Mine works but with a bad exhaust fan, want to sell yours?
Apr 26, 2009 | Soleus KY-25U Air Conditioner
Lost Manual
you can either look or download and save any manual for any model on the website
Oct 19, 2008 | Soleus KY-34 Portable Air Conditioner
My Unit is running but is saying it is full
yes you do need to drain the water that has built up. there is a little hose with a plug in it located at the bottom rear under the exhaust hose. but be sure to drain it somewhere so that you don't ruin your floor. the water of course builds up from the ac's condensor. It doesn't take all that long to get full either.
Jul 06, 2008 | Soleus KY-34 Portable Air Conditioner
Soleus Heat/Air/Dehumidfer Unit
I have had a soleus wall unit since 2005.
It is a wall unit in my apt...I have never had to use the heating part...but use the cooler part alot.
I can not figure out if that lil raindropis for adding moisture to a room...or is it to remove moisture from the room?
My apt always has to much humidity, so I do use that setting quite often, but can't tell any difference in the humidity gage.
Who knows anything about using one of these.
Sep 02, 2007 | Soleus KY-34 Portable Air Conditioner
Soleus KY-34 Portable Air Conditioner Logo
251 people viewed this question
Top Soleus Air Conditioners Experts
Level 1 Expert
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Soleus Air Conditioner Expert? Answer questions, earn points and help others
