Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Why is my Weiser Lock POWERBOLT ELEC opening when it should be closing?
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
SOURCE: Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
Posted on Jun 11, 2009
  • 26 Answers
SOURCE: my powerbolt keeps beeping short beeps and then
dead batteries
Posted on Aug 18, 2009
  • 12104 Answers
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Posted on Oct 19, 2009
SOURCE: i have an old weiser powerbolt 3000 with a remote.
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
Posted on Jan 24, 2010
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
Deleting Codes on a Weiser powerbolt.
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Jul 09, 2012 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you take inside cover off
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
Good luck--and please provide feedback if this helps!
Sep 14, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have to punch code in twice for the lock to open. The first time moves the deadbolt about 1/4 inch and the 2nd time actually opens it. I've changed batteries and it hasn't corrected the...
You did not indicate whether the problem exists only if the door is closed, or also if it operates in the same manner when the door is open. If it is only a problem when the door is closed, then you probably have a misalignment between the lock and the strike mounted in the door frame.
Here is a link to the installation instructions for the Powerbolt. It is a PDF file, requiring Adobe Reader or similar is installed on your computer:
http://www.weiserlock.com/PDFs/install_sheets/pb_eng_install.pdf
If the problem is not due to a misalignment, then I suggest that you contact Weiser Customer Service:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
They have toll-free assistance numbers.
May 29, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Constant humming from lock
Troubleshooting instructions for the Weiser Powerbolt can be found here:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Any misalignment of the parts can cause a mechanical bind in the lock if it is otherwise trying to operate.
Apr 16, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
HI: Just installed lock and programed it. it opens with the code but the bolt wont lock when the code is put in. you hear the gears moving when code entered but bolt wont lock. David
I can't help you directly, but Weiser customer support contacts can be found on this page:
Mar 06, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Touch pad does not work on weiser lock powerbolt. Batteries are new and beep when installed. Checked power board and is installed properly.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
I hope this helps.
Feb 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lock is not responding iwant to change the
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for accessing the batteries can be found there. Good luck!!
Jun 01, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
94 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
