Why my Salora CRT Model# SC2133 is not displaying any color?
Salora model# SC2133 is not displaying any color but black & white with okay picture quality. We tried replacing the Croma IC, crystal, memory IC etc with no solution whatsoever. Please assist.
silly girl
  • 513 Answers
SOURCE: no image output on screen or viewfinder
If you can see images in play mode, previously taken pics, then check to see if iris is opening and closing, could be seized vanes on iris motor. Tap on the lens(just not on the glass) repeatedly, this might help jog the vanes open. remove batteries, reinsert them after an hour, or a cup of coffee. If it persists press the reset button . all your settings will be cleared. Check to see if there's a second internal battery used for function memory, if there is, remove that one too for a while. Sounds a lot like the global CCD sensor problems that most manucturers had last year, but I don't remember anything regarding panasonic in that context. Use your warranty if valid Good luck
Posted on May 23, 2006
  • 68 Answers
SOURCE: RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Posted on Oct 16, 2006
  • 3 Answers
SOURCE: DVDs Play in Black and White
is it a uk dvd in a uk dvd player and not a copy? if so is your tv and dvd both set to PAL or PALi mode? check both one of the two may be in NTSE mode this would cause it to be Black and White OR it could be your scart cable (it wil be a pal/ntse problem) (
Posted on Feb 14, 2007
SOURCE: Change black and white to color pictures.
What you do is go to menu>shooting menu>optimize image.. and more than likely there will be a palette icon and written next to it will be BW just change it to any other icon on the menu
Posted on Mar 20, 2008
SOURCE: Half part is display
replace ic
Posted on Sep 29, 2008
Why my salora CRT TV SC2133 is not displaying any color?
Try an external AV input and see if you have color.
Other than that, without the sams for that unit, you are hit and miss.
Also, you may want to check the power supply for Bad caps.
May 07, 2014 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Color comes and goes. Why ?
Do we know a brand and model number of the TV?
Aug 27, 2012 | Televison & Video
The color green is almost totally nonexistant. Ie while watching a baseball game, the grass is brown. If I adust the color from the menu screen all the way to the maximum, the grass becomes slightly bluish...
Two possible reasons here:
1) Does it look the same when you play a DVD etc or is it just with the sat receiver? If the same either way signal is not the problem.
2) On the set, turn the color all the way off and go if you can find one to a channel that is in black and white---What color is the screen? It should be something like a black and white picture.
The model indicated has a long history of problems with the three picture tubes.
If the picture is not black and white etc there is a manual way (not with the remote) to try to adjust for this---depending on your answer to the above I can tell you exactly how to do this---takes about 10 minutes and a Philips screwdriver---you do not have to be a tech to do it.
If I have told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 13, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Our Jensen has no color. We have picture and sound, but in black and white. The display settings on the screen are in color. Anything I can do? The model is TS2750J. It's only 2 years old!
There are different types of color settings and systems - NTSC, PAL and SECAM. Are you sure the correct one is selected ? If yes then the problem is in the decoder and must be replaced since the chip cannot be fixed. This is a job for a pro.
Jun 27, 2010 | Jensen Q2749J 27" TV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
My picture is not very sharp . What might be the problem? Lamp and ballast already changed. Any suggestions?
is this a new tv what ever the problem try to see what settings you are on like factory or custom
okay if on factory put on custom and try to adjust to your likings what i like to do is take the color settings all the way down try to make a black and white tv like the old days then start bringing
the color up see what happens okay good luck
May 03, 2009 | Mitsubishi WD62327 TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Lost color on curtis-mathis tv
CHECK FOR AND REDO LOOSE SOLDER JOINTS
Nov 20, 2008 | Curtis-Mathis Televison & Video
No Color on my Audiovox AVT-1498
That model has a history of bad solder connections in various circuits. I would not be surprised if that is the case with the color circuitry. You may get the color to come and go by slapping the sides of the TV or lifting one corner about 1/2 inch and dropping it. If it does, it is a bad connection and possibly fixable. If no change is noted, it could be a bad semiconductor or capacitor, etc., causing the symptoms. For that size set, it would probably be cheaper to replace with a different brand. Toshiba has a nice 14" model IMO.
Feb 11, 2007 | Audiovox AVT1498 TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
