Question about Cameras
I have a Fujifilm FinePix S9600 and the zoom lens is turn all the out 300mm and dont want to turn back. Just got the camera a day ago bought it 2nd hand
    Top Expert:
  • Cameras Master
  • 6,702 Answers
For your camera there is still a manual online. Check out with Fuji.
When something strange happens with your camera, the best thing to do is to remove the batteries for a few seconds. After you reinserted them, you can switch on the camera again, and wait what happens. If the lens did not come back, because of a software problem, or just because you touched it while it came out, this could solve the problem. If any mechanical problem, like a defective motor, gear or even en electric one, like a broken connection. nothing will happen. If the camera won't retract the lens, I would go back to the person who sold the camera and asked him to solve the problem, or to give back the money.
Posted on May 08, 2014
SOURCE: user manual for finepix s 5600 digital camera
Go to: http://fuji.fi/documents/12/S5600.pdf ... and you can download the manual for free in about 30 minutes! Brenda
Posted on Apr 03, 2009
  • 586 Answers
SOURCE: fujifilm finepix a820 zoom error
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Posted on Oct 28, 2009
Testimonial: "thankyou for your advice"
SOURCE: I just bought a FUJIFILM Finepix j38 less than a
u have a 1 year warranty. i would contact the business u bought it from because fujifilms customer service SUCKS
Posted on Nov 24, 2009
  • 11967 Answers
SOURCE: i have a Fujifilm camera finepix j38 and when i
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 12, 2010
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Posted on May 03, 2010
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Jan 01, 2016 | FUJIFILM Cameras
Hi, I have the finepix s9600 and was wondering if the zoom lense could be changed on it for a higher zoom?? if so what would you recommend
The S9600 camera is a fixed lens camera and the lens ca not be changed not like a DSLR with interchangeable lenses. Your camera has the equivalent of 28 to 300mm focal length which is pretty respectable. One thing you could do is purchase an adapter but the quality of your pictures will suffer. Going to a full DSLR with the focal length you have now wouldn't be to cheap either.
Dec 26, 2010 | Fuji Finepix S9600 Digital Camera
Fujifilm finepix J32 Zoom error
Had exactly the same problem with my fujifilm j32, after reading a few things on the net and definitely couldn't be bothered to waste money and time sending off a camera that cost a few quid I took matters into my own hands!
I turned the camera on and quickly grabbed the lens to stop it retracting again, once it was held out I gave it a good 'wiggle' moving it in all directions fairly firmly!
I then pressed the on/off button again to switch it off and then turned it back on and low and behold it turned on and worked perfectly after!
Hope this helps others cause it could save you a lot of time and money!
Feb 19, 2010 | Fujitsu Cameras
Idiots guide to S9600
Join the fuji forum and ask your questions there, loads of s9600 owners there
http://www.fujifilm.co.uk/myfuji/
Feb 21, 2009 | Fuji Finepix S9600 Digital Camera
Fujifilm s9600 cf memory card is not initialized wot can i do
If possible you can copy the directory with you pictures and clear it out the format the card and copy back the empty directory. I hope this works I need the directory for my card if it works post it..........
Jan 13, 2009 | Fuji Finepix S9600 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
S6500fd,s6500 lens types.
The lens is a 28-300mm zoom and is permanently affixed to the camera (s6500fd).
The only extras are listed here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/d-slr-long-zoom/finepix-s6500fd/OptionalExtras
Dec 13, 2007 | Fuji FinePix S6500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
