Question about HP PSC 500 All-In-One Printer
Why is my canon e610 printing crooked horizontal lines?
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
I have a canon 4570 imagerunner,the problem i am facing is when i am printing a copy 2(sometimes 3) horizontal lines appears on the print.please sugest. Thank You
If the lines repeat in a regular fashion, with a consistent distance from each other, you need to replace the imaging drum. I would take a print out with the horizontal lines on it, then fold the paper up until two of the lines overlap each other; this will tell you the general diameter of the drum and give you an idea of what to look for inside the machine.
-David.
Nov 03, 2010 | Canon imageRUNNER 4570 Copier
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon MX310 not printing properly
If you are running Windows XP, you should be able to go to Control Panel> Printers and see your printer. Right-click and go to properties. From there you should be able to align the print cartridges and that should fix the problem. If problem persists, contact your manufacturer.
Jan 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Horizontal lines when printing in color from Canon printer
* check wheather cartridge is fine
*see any loose connections in printer
Apr 03, 2008 | Microsoft Troubleshooting Your Web Page...
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
