Question about Precise Biometrics Office Equipment & Supplies
Precision pb 100
My scaner's sencer not propery working ,reqired qty minimum 1 maxi 5
How do I replace rear parking sensor
You have to take bumper cover off .
Remove rear bumper fascia. Refer to Rear Bumper Fascia Replacement . Disconnect electrical from the rear object sensor. Lift the locking tabs on the housing and remove the rear object sensor.
Preliminary Procedure
  1. Remove the compartment sill plate. Refer to Rear Compartment Sill Trim Plate Replacement .
  2. Remove rear wheel liners. Refer to Rear Wheelhouse Panel Liner Replacement .
Rear Fascia Push Pin Retainers (Qty: 2)
Rear Fascia Nuts (Qty: 4)
Tighten
10 N?·m (89 lb in)
Rear Fascia Bolts (Qty: 2)
Rear Fascia Bolts (Qty: 6)
5
Rear Fascia
Tip
Energy absorber and fascia are removed together. Cannot be separate on vehicle.
Disconnect the electrical connectors.
Dec 22, 2015 | 2006 Cadillac DTS
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
Pb 100-f
Download of driver pb-100-f
Apr 25, 2014 | Precise Biometrics Office Equipment &...
Where can i take my car for full tune up and how much should it cost
Took our to dealer, they talked me into several other things cost was almost $700 dollars. We later found out that our independent car repair person would have done this for 1/5 the price. Don't take to dealership....what a ripoff Hubler chevy ripped us off and charged over $100 per hour to check radio speaker.
Feb 06, 2013 | 2006 Chevrolet HHR
A shortage of 100 kgs in chemical A, of 140 Kgs in chemical B and Of 50 kgs in chemical C was noticed due to breakages. At Mumbai, the manufacture paid octroi duty @ 0.20 kg. He also paid hamali, Rs 20 for...
CASE STUDY - 1
Chemical A
Chemical B
Chemical C
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Cost of Chemicals
6,000.00
4.20
25,200.00
10,000.00
3.80
38,000.00
4,000.00
4.75
19,000.00
VAT
630.00
950.00
475.00
Railway Freight
300.00
500.00
200.00
Octroi 2%
504.00
760.00
380.00
Hamali
20.00
58.12
30.75
Total Cost
6,000.00
26,654.00
10,000.00
40,268.12
4,000.00
20,085.75
Less: Shortage
-100
-140
-50
Net Qty Received
5,900.00
26,654.00
9,860.00
40268.12
3,950.00
20085.75
Normal loss
-236
-394
-158
NEED ANSWERS CONTACT ME AT aravind.banakar@gmail.com M : 09901366442 / 09902787224
Aug 30, 2011 | Computers & Internet
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
cheers hope it helps
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Scans from the Dell is quite large.
you can reduce picture size using any photo software best is photoshop, you may have microsoft picture viewer, and a lot of soft. Scaner may not let you less then 72dpi to get normal picture for print.
Aug 05, 2009 | Dell 968 All-In-One Printer
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Change headlight
hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. http://gsi.xw.gm.com/image_en_us/gif/000/001/725/1725371.gif Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs http://gsi.xw.gm.com/image_en_us/gif/000/001/728/1728611.gif Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension http://gsi.xw.gm.com/image_en_us/gif/000/001/733/1733942.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia http://gsi.xw.gm.com/image_en_us/gif/000/001/736/1736893.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
Jun 13, 2009 | 2003 Cadillac CTS
Replace o2 sencer bank 1 circuit 1
You should be able to reach it from the top. It is a stretch. The hardest part is getting it out. If you have the new part already you can cut the wires and use a regular socket wrench to get it off. Some like to run the engine for a minute or two before starting. Soak it with PB Blaster, wait a minute, and go at it. If clearance is an issue, try a box end wrench. The socket designed for the O2 sensor has a split in it that sometimes can spread. It is also hard to use the knuckles as they deflect a lot of torque.
Once it is removed, make sure that the paste is on the threads. This will help the next time this needs to be done. Thread it in, torque it down, and plug it in ( the plug is on the alternator bracket.)
Apr 29, 2009 | 1996 Dodge Caravan
Top Precise Biometrics Office Equipment & Supplies Experts
k24674
Are you a Precise Biometrics Office Equipment and Supply Expert? Answer questions, earn points and help others
