Question about Meiko DV 80.2 Dishwasher
Error 702 when start machine it drain all water and do not take water
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Hover DYN 7164 error E16
OK Anthony! Now you have enough money to FIX the machine! LOL. First One error begets another. So forget about the errors! You are focusing on them too much! You told yourself whats wrong with this machine! OK Give Up? It is Not Draining! It is your Drain Pump Lad! Go and buy a new one, replace but remember to unplug it first. Don\'t due all that other stuff. Run the machine afterwards on a short cycle and guess what? No water!
Jan 20, 2014 | Washing Machines
Washing machine error came up when trying to drain, so used tube to empty water out of machine and cleaned pump.this seamed to work as error sign didnt come up and machine started to work again but when it...
Something has clogged the drain hose or pump & caused the internal drain hose to split by replacing the hose you will clear the blockage the pump also may need to be replaced also.
Feb 21, 2011 | Zanussi Washing Machines
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Kenmore Elite smartwash QuietPak9 F H error code
Press the Pause/Cancel button twice to clear the display then check if water is introduced into the machine. Drain the water from the machine by selecting Drain and Spin then pressing the Start button for one second. Empty the machine after the water is completely drained.
Start a new cycle with Hot/Cold water temperature and check how long before the error code appears after the cycle is started. When the code appears, press the Pause/Cancel button to clear the display then check again if water is introduced into the machine.
The pressure switch is not tripping and must be replaced if the error code appears about 8 minutes after the cycle is started and about 40 liters of water is introduced into the machine.
The flow meter is not working if the error code appears less than a minute after the cycle is started and about 3 liters of water is introduced into the machine.
The valve solenoids may not be working or the levers are stuck if the error code appears less than a minute after the cycle is started and no water is introduced into the machine.
Let us know which case above is observed for specific troubleshooting and repair guide.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer just beeps doesn't start error code says "lol"
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Washing Machines
Washing machine not starting
Jan 03, 2009 | Washing Machines
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Dishwashers Logo
69 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
ray gallant
Mister Danger
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
