Question about Cooktops
Flame in cooktop (3rd one) seems to be mostly blue with orange tips appearing here and there, but is agressive and pots almost burn with food not cooked. No way to turn down on a sealed cooktop. Is this normal for cooktop? Sears said everything looked good, but went back to an older model, still sealed GE. Same result
    Sergeant:
  • 212 Answers
If your on propane you will get a little bit of a orange tip. need to see if your model has shutter valves. this adjustes the gas air mixture
Posted on Jun 22, 2009
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Front right burner has high flame on left and low on right had a service call and GE tech said this is normal so you don't get pot handle hot, sounds absurd to me. Any input
Are the burners uniform around top? Pictures show that there is a slot on one side. The tech is probably right.. You are not the only person complaining about this. Call back and see if there is a different burner that will fit you stove.
Dec 20, 2017 | GE PGS968SEPSS Profile 30" Slide In Gas...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Looks like the flame burnt the stainless on my cooktop. Only had it 2 months and now there are 2 blue stains on it :(
I have the same issue - front left burner - two blue burn stains. Have you found any solution to this yet? major bummer.
Mar 05, 2011 | Thermador 37 in. SGSX365 Gas Cooktop
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
Hi - I have a 4 burner GE gas cooktop. The clicking sound comes from all the burners but 2 of them are difficult to light. If I hold my hand over the top ... they will light! Is there an adjustment that...
Usually this happens if something has been spilled or a pan overflowed and is partially clogging some of the burner holes. Make sure the burner holes are clear and try poking them with a sewing needle to make sure. I am assuming the flames are a nice blue color and not a lazy yellow or yellow-tipped. If there is some orange, that is usually an indication you are burning off some food and will need to be cleaned. If that doesn't appear to be the issue, then let us know and we'll dig deeper. Douglas
Sep 18, 2010 | GE 30 in. JGP328 Gas Cooktop
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Amana cooktop
Hello dishmama1, is this a sealed burner cooktop? If so then remove the cap and make sure all the holes are clean. Restricted burner holes can cause and issue with the flame. Also with it off make sure the area where it sits is clean and the cap sits flat. Hope this helps
Aug 09, 2008 | Amana AKS3040BSSCooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Cooktops Logo
90 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
