If you repeatedly get low battery messages from your thermostat, or if there's another power-related message, you may need to check the C wire connection or install a C wire to provide consistent power to your thermostat and prevent the backup batteries from draining.
As usual, the devil is in the details. In this instance, it depends upon your model of the device, whether it was compatible with your particular system, whether you have set it up so that it actually functions, and whether it passes a system test. It is hard to bypass any of those and get a credible answer to your question --unless you just get lucky and can ignore all but the last.
Other assistance below, the first of which may be particularly helpful. The last links to the home page where support might be sought. The middle is just a YouTube installation video:
sounds like a mouse nest in hvac system, no smell because when using ac it doesn't use outside air, probably a nest on the screen at the hvac air intake or if you have a a cabin air filter check in there. many times rodents make nests have babies and then the car moves and they cannot feed the babies and so they die and rot smell comes into car. usually it is not hard to access because there should be a screen between the outside and inside under the cowl cover, if no screen and the little buggers vot into your hvac duct system this could be a much bigger problem entailing removal of dash completely. most likely this isn't the case, good luck
i also have a 2008 avenger rt.its o good thing your car is under warranty it is must likely the turn multifunction switch.which controls a lot of stuff light turn signals brights. i hope this helped please rate this answer thanks.
