I have portable dental compressor only fan is working and compressor is not..what is the problem ?suggest a solution on drnadeem007@yahoo.co.in
  • danny tan
    danny tan Apr 04, 2017
    check the capacitor, it could be damage
  • 98 Answers
The over load switch may be cutting electricity or compressor unit may be out of order.
Posted on May 09, 2014
I Look For Professional Cosmetic Dentistry At Agoura Hills. Can Anyone Suggest A Dental Service?
Cosmetic dentistry Agoura Hills CA is something for which you should choose a professional dental service. Firstly, you should feel comfortable and only then you will start believing the service. I got such an experience with Agoura Dental Group. The dentists Agoura Hills CA working for this group were very much kind enough in explaining the cosmetic dentistry procedures they have in place for addressing different dental issues. Right from dental braces Agoura Hills CA, they also offer teeth cleaning Agoura Hills CA and many other useful dental services to improve your smile. Resource https://agouradental.com
Mar 06, 2018 | Health & Beauty
My 26lb silver portable ice maker wont make ice?? Any suggestions???
does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My portable dental compressir is not starting up only the fan is working
Try this, disconnect from power source and let it cool down to room temperature. If the unit over heats it will go into a thermal cutoff.
The compressor has a bi-metal temperature sensor attached to the body. In most cases it is along side of the compressor terminals.
While you are in that area, look for burnt wiring or loose wires.
Assuming that the compressor has over heated and in a thermal, try restarting the unit and see what happens.
If it still wont start and is not tripping breakers, check the start/Run capacitor for bulging or leakage.
May 07, 2014 | Heating & Cooling
Does this dental air compressor have a oil pressure safety switch?if so, where is it located? can I find a wiring diagram
Air compressors are designed to operate many different tools. The value of a commercial air compressor is many times greater than the purchase price because of the amount of work a single air compressor can perform. Dental air compressors are some of the most reliable because of the high-quality air they supply and precision tools they operate. As a result, dental air compressors can be adapted for a number of different tasks, including artistic air brush painting
1.Disconnect the air compressor from the dental tool air supply. Pressure and air supply rate-of-flow settings are different for air brush painting than for air delivery for dental tools.
2.Reset the air pressure on the tank to a range between 15 and 20 pounds per square inch (psi). The exact operating pressure for airbrush painting will vary, depending on the application and the type of paint used.
3.Reconnect an air-supply hose and a siphon style airbrush to the compressor.
4.Fill the airbrush's paint vile with lacquer-based paints. Test the air brush and paint performance on a piece of cardboard, or scrap piece of cloth
material before beginning the painting project. Every time the air compressor is connected to airbrush, or a new paint color is loaded into the brush, a short test spray should be performed. After each test adjust the air volume, and the paint flow in the gun to achieve the desired results8_16_2012_1_32_17_am.jpg
Aug 04, 2009 | Air Tools & Compressors
Running hot
contact email vaigaienterprises@yahoo.co.in
Mar 25, 2009 | Invacare Supply Group Invacare Corp...
Compressor is not kicking in
Probably power surge shorted out the main board. If so it will need to be replaced. Gotta call for service.
Jun 09, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
