Question about Pioneer PDP-5060HD 50 in. Plasma Television
Blue light blinks 10 times on pep-5060hd - Pioneer PDP-5060HD 50 in. Plasma Television
Philips 42 PFL7962D do not turn on. The blue light go on and blinking after every 10 second.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 05, 2014 | Televison & Video
There is a blinking blue light under the fan symble that comes on every hour, and wakes my wife up.
when mode you selected will be operational the blue light will blink.every time before the cycle begins the blue light will blink with the slight delay of 10-30 sec.
Sep 12, 2011 | Danby DPAC90061 Portable Air Conditioner
My pioneer plasma PDP 5060HD Media Center control box has red blinking light, blinking once every second. No power to plasma display and unable to power on media center box. Recycled power to both plasma...
lenwas,
I have the exact same problem with the same model tv. It just stopped working, tv has no lights or evidence of power and the red standby light on the media center flashes without any other function potential.
I checked the internal tv fuse and it was measuring continuity.
If you figure anything out I'd be interested to hear it.
Tom
Jan 05, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
How to retrieve without a scanner the fault code on jeep grand cherokee limited 1995
buy a middle of the road good scanner for 150.00 at pep boys well worth it!
Jan 04, 2010 | 1995 Jeep Grand Cherokee
I am trying to find the blinker relay on a 1988 chevy blazer....
its the fuse. wen a bulb blinks fast and cuts in and out its the fuse for the blinker. buy it at pep boys or any part place
Jun 04, 2009 | 1988 Chevrolet S-10
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
BLUE POWER LIGHT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Jan 26, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer PDP-5060HD 50 in. Plasma Television Logo
22 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
