Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel GW711 not spinning and - Fisher and Paykel GWL11 Top Load Washer
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
SOURCE: On our Fisher and Paykel, the spin cycle does not
what modle do you have how old is it does it power down and turn off or does it stop and start beeping at you have you tried it with no clothes in it and if so does it do it then , these machines are very simple as they have vert few machancal parts post a phone number and i will call you
Posted on Feb 28, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Posted on Jan 06, 2010
Fisher and paykel gw711 balance reset
normally if u unplug the appliance for a few minutes then plug back in , it should reset everything? not sure bout Pykels though
Nov 09, 2014 | Fisher and Paykel Washing Machines
My old Fisher and Paykel GW711 washing machine worked fine until I moved house. It worked fine a few times here, too. But now it fills, but then doesn't start the wash cycle, then after about an hour, it...
sounds like an electronic problem. motor controller most likely. I am unsure off hand what this fault (7) means, but the number is very low, which normally indicates motor control board
Sep 12, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
F & P washer does not start
These 11 series machines all have this problem
When power supply gets warm it stops.
You will need a technician to fix the power supply in the brown board.
Mar 13, 2012 | Fisher Washing Machines
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GW711
is it making a humming sound at the spin,is it draining you may have a blockage try turning the black fan on the pump front right underneath.hope this helps.
Mar 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
35 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
