Question about Smeg Ovens
The igniter on my SMEG gas stove does not work
  • 957 Answers
They do go bad from time to time. you can get a new one at appliancepros.com or you can goole appliance parts and it will give you many vendors to chose from
Posted on May 08, 2014
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Smeg SE290x-5 oven stopped working
Replace igniter if gas .or if elect replace element
Nov 09, 2011 | Smeg Ovens
Nothing happens with the ignition, no spark at all. I now have to light hob with a match
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 16, 2010 | Smeg S300X Electric Single Oven
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
I want to change my smeg oven element please smeg
i hate my electric oven how can i change it to a gas stove
Feb 13, 2010 | Ovens
How to reset SE 108 x
Customer Service
Here are three things to try. First, on page 64 of the following manual link below, it discusses how to delete the data to the timer clock before turning off the oven. More about programming the clock precedes that but it looks like something you could try. Secondly, I have to wonder what would happen if you just unplugged the stove and left it unplugged for maybe a half hour. Maybe it would magically reset the function of concern. Lastly, you might consult the SMEG techarea below. If that gives no satisfaction, you may have to consult a SMEG technician. Here is a google link to the manual I was examining followed by the smeg tech webpage link which you can register for to use:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiQp8_spt3VAhWGQiYKHZCyD9cQFgguMAE&url=http%3A%2F%2Fwww.smeg.co.nz%2F%3D%3DihtNy8jZPYfrOmUNPKkD9A%3D%3D%2FUSERS%2520MANUAL.pdf&usg=AFQjCNErxuPY_fiXPK7Aop9YNSPCpA6PZA
SMEG TechArea for registered users:
www.smegtech.com
Aug 17, 2017 | Stoves Ovens
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
SMEG Oven SA9066XS
If this is an Electric over, the heating element is damaged. The device has a open connection. These element break down often. Usually, the manufaction will sell this whole element as one fixture. They are usually easy to replace.
If it is a Gas oven, the polit is out. Sometimes they go out, and its ok to relight them. But this sounds like an Electric over!
Oct 22, 2008 | Smeg Ovens
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Ovens Logo
297 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
