Question about Baumatic Washing Machines
Why is BWR1206 not doing full spin
Why is the machine not doing a full spin
My machine is doing the full circle . And theres no water left in machine but clothes not rinsed properly . Actually still soaking can you help
Number of possibilities here. Uneven load not allowing to go into full spin (try with no load and see if it goes into full spin), blocked filter or maybe motor brushes. Three most likely suspects.
Jun 20, 2017 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Washer stopped while it was full of clothes and wont drain/spin
this is the problem with my machine what do you think i should do?
Nov 25, 2009 | Whirlpool LSR7333 Top Load Washer
I purchased a whirlpool washer (model # WTW5600SQ) in 12/07 and the spin cycle does not effectively remove enough water from the clothes. The clothes,after the spin cycle completes, are still very heavy...
Hi Tim, Check the filter to see if it blocked .. also, take note to see if the machine is gathering a full spin speed, if not, you may need new brushes in your motor
Aug 21, 2009 | Washing Machines
Hi my hotpoint washes but wont do a second spin,just had new door lock fitted
Most hotpoint machines can be a bit sensitive on the balance control. If you have a half full machine, somtimes it wount spin as high as you want. It will try some spins until it finishes without high spin.
Jul 27, 2009 | Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
Machine not reaching full spin speed.
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine.
Jul 10, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
noel
noel
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
