Question about Navman S35 Handheld GPS Receiver
A110 hard reset
Canvas 2
My airtel Sim is not working in my micromax canvas nitro2 plez help me
You have Check sim management setting of the phone.
Check the video and do the setting in you phone. even the video shown is for another model number , hope it would match for your phone too. the demonstration is in HINDI. hope you will understand.
http://electro-medical.blogspot.com/
micromax a110 canvas2 Sim management settings
Nov 08, 2015 | Computers & Internet
Micromax A110 canvas 2 power button not working so how to start the phone ?
just short two point of power switch than insert battery its direst power ON
Aug 03, 2014 | Cell Phones
How to open pattrn lock
put ur phone in power off mode and hold vol up and power key at the same time. den phone is on factory mode use reset factory and its take some time pattern lock is open. :-)
Feb 11, 2014 | Computers & Internet
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
Micromax a110 canvas 2
you need to get a new phone or you need to get a new smartcard or go to vodaphone or metor and complain
Aug 04, 2013 | Cell Phones
Will not allow anything
Dear solution provider,
I am using A110 Canvas Micro Max brand, in that mobile, touch screen is not working in messenger send option only and it require to press very hard
Mar 08, 2013 | Android Huawei
Micromax a110 touchscreen problem
How to rectify the Touch screen problem.
1. Some time require hard touch.
2. IN messenger, we unable to send the item due to touch issues on send box
Feb 18, 2013 | Cell Phones
Navman S35 Handheld GPS Receiver Logo
13 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
