Question about Midea 24,000 Btu 17 SEER Inverter Mini Split Heat Pump AC : Energy Star
E4 error on screen
AC switches on but after 5 to 10 minutes the unit switches off and displays an E4 error code. How can it be fixed?
  • 2,133 Answers
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
Posted on May 07, 2014
  • ramesh Apr 07, 2015
    There is have a coil sensor problem?
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
E4 error being displayed
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
Midea 24,000 Btu 17 SEER Inverter Mini Split Heat Pump AC : Energy Star Logo
1,344 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
pawnpower
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
