Question about HP Pavilion Computers & Internet
How do I connect a data projector to a HP Pavilion 10
I am trying to connect my HP Pavilion 10 TS 10-E004 AU Notebook to a NEC NP-M260X data projector using a HDMI to VGA converter cord and the screen keeps on flashing, it shows up for a second then flashed off again, then a green or blue screen and this goes on until I pull the cord out. I have tryed adjusting the aspect ratio/screen size on both pieces of equipment and lowing the refresh rate on the laptop, could you please help with what other options I should try? As the picture does show up I don't think it is the cords, but? Thanks
  • 91 Answers
Have you ensured you have the drivers for the projector? As you are using a cable, it may be as easy as going into your Device Manager and checking for any warning icons...typically under the Monitors, and Display Adapters. Connect the cables, and open your Device Manager, then click to scan for new Hardware. if any of the drivers regarding display result in the warning select to update the drivers. Allow it to do so automatically, as I am not certain is HP has the driver on their website: HP Drivers Downloads It may not list your exact device, but many drivers work for multiple models.
Posted on May 07, 2014
All Office
  • 58 Answers
SOURCE: HP Pavilion dv6000 laptop wont boot up
Try this first, Press the F8 key a couple of times when starting up. This should get you into "safe mode" and you'll need to go into the Help and Support section and do a system restore back to a restore point. If that doesn't work, then you might need to do this: 1. Press F11 on the keyboard immediately while the computer is starting up. The HP Backup and Recovery Manager window will appear.
2. If the Recovery Manager can access the hard drive it displays a prompt to backup up your user files before continuing the recovery. If it cannot access the hard drive to fix the system errors, the Recovery Manager starts recovering the hard drive to its original condition.
Of course doing the F11 process will wipe out all your files and reset the drive back to the factory settings.
Posted on Jan 22, 2008
SOURCE: My HP Pavilion dv6000 won't turn on
I've had the same problem.
Remove the battery & power cord.
hold down the power button for 10 sec to release any residual power.
plug in the power cord but leave out the battery
it should boot right up
Posted on Oct 13, 2008
SOURCE: My Acer Aspire 5100 wont start up correctly
I had the same problem after running an update to my Norton anti-virus software. When booting the laptop, press F2 to go to the setup menu. One of the options allows you to change the order that is searched when booting up. I moved the boot from hard drive to the last option, allowing it to boot from a network first (which it doesn't find), then from a portable device second (which it doesn't find), and finally from the hard drive. When I boot up, after it doesn't find the first two options, it boots from the hard drive with no problem.
Posted on Nov 12, 2008
  • 36 Answers
SOURCE: how to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Posted on Jan 16, 2009
  • 50 Answers
Hi sounds like your dc connector in laptop is loose or bad connection.Try moving the power cord going into the laptop gently and watch the lights to see if they flicker off .If they do you need to take the laptop in for repair.
Posted on Jan 20, 2009
Whin i plug vga cable screen flickering
Hi Prakash
Clean Connector Pins with spray
Wiggle to see if bad connection
Check for Female socket loos worn holes in connector pin
Sep 12, 2015 | NEC NP-M260X LCD Projector
NEC NP-M300W projector: Lamp status RED, replaced lamp still RED. Status indicator GREEN. Won't power on.
On the remote control of the projector, press and hold the HELP button for 10 seconds.
Aug 26, 2015 | NEC Office Equipment & Supplies
Nec NP-M300w computer inputs flicker on and off
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2014 | NEC NP16LP Projector lamp RPLMNT LAMP FOR...
Nec np-m260x red lite nine time bliking
your dynamic contrast function is not working properly. you might need to take it in to get repaired
Mar 02, 2014 | NEC Office Equipment & Supplies
After around 1 minute the lamb goes off and the system goes to standby
the lamp is good one, it is ok .the mother board is ok
it seems like the fans is defective
pls check every fan in the projector
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 21, 2014 | NEC M260X LCD Projector
Cleaning dust from inside of lens of NEC NP 100
I would try not to touch it much. Having a single smudge or finger print on the lens will look bad on the picture. just use a blow air can or blow on it. If need get a mico fiber cloth.
Feb 01, 2014 | NEC NP-1000 Projector
Reset lamp hours nec projector np-ve281
If you wish to get some details; check the site linked here. Pull up older posts.
Jan 26, 2014 | Nec Display Solutions NP-VE281 DLP...
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
