Question about Tools & Hardware - Others
I want to reassemble the filter of kent ROflow diagram kent ro
  • 3,368 Answers
Try this link it should help you:
http://www.kent.co.in/pdf/Kent_Grand.pdf
Posted on Jul 21, 2014
I have a culligan ac-15 ro system and changed the filters. Put back in excatly like the diagram shows and now in 2 days it only makes about 3 cups of water. The tank has 7 psi and if I take out the...
RO membranes are made of plant material and they can spoil if they are unsealed and sat for a while in the warehouse. Even a small hole in the storage bag could cause problems.
Aug 18, 2014 | Tools & Hardware - Others
Water comes very slowly from Kent RO faucet and to fridge.
If it has only been one year, check the warranty. Who said that it needed to be replaced? Oftentimes, a repairman can adjust the pressure to increase the outflow without needing to replace the whole unit.
Elisa Jed ' http://www.multicrafthome.com
Nov 18, 2013 | Culligan Under Sink Water Filter
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
Aug 02, 2017 | Maytag MSD2734GE Side by Side Refrigerator
For Culligan Aquacleer AC15, Carbon and RO filter oring to be mounted towards end of cartridge or manifold?
Here is a manual for a Culligan H-30. Basically the same unit. The diagram shows how to replace o-rings.
http://www.freshwatersystems.com/support/H-30.pdf
RJ
Oct 17, 2011 | Culligan Under Sink Water Filter
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
I need a water diagram for a culligan water system serial number is AC10001293
Here is a link to the Culligan website for the AC 30 owners manual. It has a breakdown view of the RO.
http://www.eculligan.com/support/ac30_owners_guide.PDF
This is about as close as you will get to a water diagram for the RO. The only place to find a flow diagram is in a service manual and those are well protected by Culligan.
RJ
Jun 19, 2010 | Culligan Under Sink Water Filter
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
Have a kent r/o system dont know how to hook it up is there any way someone can help
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 13, 2009 | Culligan Under Sink Water Filter
Water leaking from top of RO system.
is there an internal float that is stuck allowing overflow?
Nov 18, 2008 | Plumbing
Tools & Hardware - Others Logo
174 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
