Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Mono to stereo
I have sony trinitron J21" tv which is having mono audio input & output
i want to convert it to stereo.
how can i do that?
  • mkbutan Jun 22, 2009
    i have sony trinitron KV-G21PD1/B tv which is having mono audio input & output
    there is empty space for the components on the ckt board
    how can i do that?
    President:
  • 2,992 Answers
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Posted on Jun 22, 2009
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
Sound
You should be able to do so through the menu on the TV. Look for a "MENU" button of some sort on the TV/Remote, then scroll through the settings.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
I have a sony trinitron wega - I know it is old but it is still great -- I need some advise on getting a pvr -- what should I look for
Actually, the TV is only a display device. It's just there to show you the picture from the PVR, and you're free to pick any model PVR with the features you want and a price you like. The only thing you need to be concerned about is connecting the PVR to the set.
Your Sony should have audio and video input jacks on the rear panel. (I'm assuming you have a Sony since your question is posted under that heading, but that's not always the case.) Almost every model has at least one set. These older models usually only offer composite video input with a single yellow RCA jack, and a pair of jacks (red and white) for stereo audio input. When you pick a PVR, just be sure it has a composite video output available. I haven't seen one yet that doesn't, but there a lot of models out there. If your model also happens to provide a component video input (with three RCA jacks, colored red, green and blue), that's even better. Component video gives better performance, and it's a standard output on PVRs and other video devices.
All you need to do is connect the PVR video output to the TV and select that input. You can connect the audio output to the TV, or use your home stereo receiver and speakers instead if you have a system. This might give you enhanced sound performance.
If your TV is a model not equipped with AV inputs (true for some very basic models, especially smaller screen sizes), you'll need an RF modulator. The TV can only pick up signals from its tuner, and that's where the modulator comes in. It takes the video and audio from the PVR and makes a channel 3 or 4 signal to the TV's antenna input. You might find a PVR with a modulator built in, but that's pretty rare now.
Jun 25, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I want to get a mono audio output from the TV audio sockets to combine the L&R channels to a magnetic loop amplifier. At present I only use the R channel) I want to keep the main sound as-is so that...
I assume you are taking an output from either the "Phono" or "Cinch" sockets on the TV.
There are leads available that combine left and right channels to one output. All you do is buy a Phone lead with the correct plugs on it. The lead will be a stereo lead. Cut the cable and join the screen/braided outer wired together. Connect the TV stereo inners together and you have a mono output. The TV has a buffer to ensure no damage is done to the sockets. If you want you can use a pair of 10k resistors in a "Y" configuration but as it is not a balanced amplifier input, it really doesn't matter.
Just use one of the plugs for your Induction Amplifier and you will get a mono signal on your loop that contains all of the audio information.
Hope that helps.
Nov 14, 2010 | Samsung LN26C450 26 in. TV
KAC-9104D output terminals
This feature allows the amp to be paired to any stereo. The input may be in stereo but the amp then changes it back into mono using sound from both sides. Hope this answers your question.
Jul 23, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Sony KV-20FS120
Do you get sound when you play a dvd thru audio/video inputs?
If this unit has audio output at the back run audio to amp and see if you have audio thru your stereo
Jul 23, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
20" RCA television
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
May 12, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
What channell do you tune to for dvd output for durabrand model Dwt 1905
I believe its not on a channel but on VIDEO. Chances are you have the DVD hooked up as Audio/Video using the RCA cables (yellow, red & white). The TV must be set to Video IN not TV Tuner/Channel. Additionally, your TV can only accept a mono audio input while your DVD's audio output is stereo. A quick and dirty way out is to use an adapter shown below to convert the stereo to mono. Additionally, to my knowledge your TV's Audio/Video inputs are on the front panel.
Alternately, if the front panel Audio/Video connector is already being used by another device, an RF modulator may be used and this time your TV has to be switched to a channel prescribed by the RF modulator. A fine example is one from RadioShack.
In some instances, there are DVD players that has a built-in RF Modulator and normally uses either Channel 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 18, 2008 | Televison & Video
TV upgrade in my Motor Home
You have to convert the coaxial digital output to non digital right left output! this is done with an adapter which you can get from EBay for $7.79 and free shipping! go to mEBay and search Toslink Digital coaxial signal to Analog converter audio adapter rca! good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 10, 2017 | Sony XR-CA330 Cassette Player
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
260 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
