If I may add to e
eagle338‘s posting, it would seem that you need:
1.
setup
diskThere are no setup files for the Wireless Access Point/Router Belkin F5D7130. However, you need driver/installer/setup files for the Belkin Wireless G Notebook Card F5D7010. These files are OS specific and must match the version of your card.
2.
passwordIf you have done the reset & restored to factory defaults then you don’t need a password (leave it blank) to Login, simply press Submit in the Web-based User Interface. If for some reason you cannot login, you may have to do the reset & restore to factory defaults (again)
3.
access
the unit (I assume the router); I can't access the unit on 192.168.2.1 (as per manual)You need to be wired to the router from your PC, connect a LAN cable from your PC’s NIC to the RJ45 Ethernet Jack at the rear of the F5D7130. In your PC, assign static (“Use the following…”) IP Address to your PC - 192.168.2.200; Subnet Mask - 255.255.255.0. Open a browser and type “192.168.2.254”, the Web-based User Interface will open. If you have done the reset & restored to factory defaults then as earlier stated, you don’t need a password (leave it blank) to Login, simply press Submit.
5.
where
can get the setup cd or software?This
site list all the versions of a F5D7010 as well as the appropriate drivers (all are downloadable). And yes they are ".exe" files.
Based on your post “
I have reset the unit.”, pls be informed that there are 2 reset methods. Determine which one was performed.
a. Resetting the WAP - Push and release the Reset button. The lights on the WAP will momentarily flash. The Power/Ready light will begin to blink. When the Power/Ready light becomes solid again, the reset is complete.
b. Restoring the Factory Defaults - Press and hold the Reset button for five seconds then release it. The lights on the WAP will momentarily flash. The Power/Ready light will begin to blink. When the Power/Ready light becomes solid again, the restore is complete.
Hope that your concerns were all addressed and that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
