How do I set up remote live viewing on my I pad
I have tried to connect my CCTV network system to my I pad but I am having problems. I have the CCTV working on the internet ok but when I try to connect it to my iPad for remote viewing it asks for system name,DID number,Password ,I have tried all combinations ie the system of the wireless network ,password of network,and the DID number of t The monitor , also the system name of the monitor Sentinent The DID number of the monitor and the password of the monitor still no good can anyone help please
    Habit-Forming:
  • 62 Answers
Here is the IOS App :- MEyePro HD on the App Store
For additional help Please visit:-
CCTV Networking Technical Support
Posted on Sep 19, 2017
    Habit-Forming:
    New Friend:
  • 58 Answers
You will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
Posted on May 09, 2014
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
Toshiba Satellite won't access internet
May be IP corruption goto control panel System Hardware devices in device manager look for network adapters Click on it and uninstall. On top in "ACTION" scan for hardfware changes This will reset your connection. You may have to go to network and sharing "setup a new connection network Then click "connect to internet" Most times this will work gl
Dec 29, 2013 | Amstron Toshiba Satellite A660D Laptop DC...
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
Intel 82562v-2 network adapter wont connect to the internet, have searched online and this is a known problem but i cant find a fix. my system is an inspiron 530s and router is a netgear wgr614 but im on...
ok this is a really pretty nice question..
I guess you using windows 7!!
- Click on Start / Control Panel
- Go to Network and Internet then Network and Sharing Center
- On Network and Sharing Center on your Right where its written Task, you will find Change Network adapters. click on it
- Right Click on Local Area Connection / Properties
- In General Menu / look for Internet Protocol (IPV4)
- Double Click on IPV4/ choose use the following IP
Ip adresse: 192.168.0.15
subnet mask: 255.255.255.0
default gateway: 192.168.0.1
Use the following DNS server:
DNS1: LEAVE IT BLANK
DNS2: LEAVE IT BLANK
Press apply and ok
Close everything, your local area connection should show you: "Local Area Network Connected"
Disable your Antivirus and Firewall ( for test ) and try accessing internet it should work
Configure your browser also
IE : Tools / Internet Options / Connections / Lan Settings / Tick "Automatically detect settings"
Ok and try accessing internet.
Firefox: Tools/ Options / Advance Menu / Network / Settings / Tick " Auto Detect Settings for this Network, apply ok.Close firefox and start again it should work.
May 13, 2011 | Computers & Internet
I am looking for a Network Workstation with all accessories needed for Video Mangement System for CCTV camera Video Surveillance
Go to cctv Video Guard
These guys have great deals. Talk to the person on the website. They are there 24x7. They will give discounts on older models, help you plan and ship within 2 working days.
In case you need real security Guards to watch the cctv 24x7 over the internet for $1/day goto sms Video Guard
Cheers
TeaCii
Mar 14, 2010 | LaCie Ethernet Disk (301298U) 2000 GB...
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Lost internet connection
Try to configure your network options and properties if it doesn't work,reformat your system.This will refresh and cure the problem.
May 04, 2009 | Computers & Internet
I have just bought idea pad y530,3gb ram. I am unable to make LAN connection (both wired and wireless), so i am unable to use internet service. But i am successfully using the internet service for other...
make sure the LAN port is enabled in the idea pad and use a known good cord and port. Go unplug a working station and see if the new unit attaches. If not the problem is in the idea pad. If it does then go back and look at the Lan connect.
Jan 06, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
CCTV NETWORKING INTERNET
Best results are to use a Netopia WiFi Business Router for a DVR installation. A Siemans modems will drop the CCTV connection at random and you will have to restart the DVR manually...which defeats the purpose of having constant video being remotely accessed. We are switching to Netopia to solve our problem with AT&T and Siemans.
Dec 09, 2007 | Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
