How to change laser print cartridge for Brother 2280 DW
Need a video on how to change the cartridge, PLEASE!
SOURCE: Brother HL 5170DN Laser
I had same problem, I removed the duplex unit, removed the back and found that the fusor unit rollers had become unclipped where someone had pulled a jam out the back of the unit
Posted on May 14, 2009
pdouglasss
  • 125 Answers
SOURCE: Hp laser jet1100 prints white lines
Hi ejazmusavi:
Try this.
Toner/developing cylinder 37.7 mm (1.48 inches)
Toner/primary charging roller 37.7 mm (1.48 inches)
Heating element 56.5 mm (2.22 inches)
Transfer roller 45.2 mm (1.78 inches)
Pressure roller 62.8 mm (2.47 inches)
Toner/drum 75.4 mm (2.97 inches)
Feed roller 55.1 mm (2.17 inches)
Hope this helps
Posted on May 30, 2009
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
  • 31 Answers
SOURCE: HL-2040 Laser Printer: Brother HL-2040 Laser Printer Dos printing...
use PRN command to print
Posted on May 06, 2010
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Nov 18, 2013 | Brother DCP-7020 All-In-One Laser Printer
Problem installing HL-2280 DW for MAC OS X 10.7.5
Did you install the driver? Double click on the driver in your download list and follow the on-screen instructions.
After doing all that, you can install an automatic driver updater so that you won't have any driver related issues in the future. I can recommend RadarSYnc.
David
Dec 18, 2012 | Brother HL-2280DW Laser Printer -...
Mfc 7860 dw - replaced toner but still says
Crazy,
check the toner, probably there are some lids or tape you need to remove.
Jun 28, 2012 | Brother MFC7860DW AllInOne Laser Printer
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black dots on printed page from Brother 9440 color laser printer
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Jan 18, 2010 | Brother MFC-9440CN Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Intellifax-2280
Brothers have a year guarantee take it back to where you purchased or call Brothers. Do not know model, grinding many times come from fuser, or drum cartridge and on many models toner cartridge....
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2040 printing watermark
does the printer do it from beginning? or after cartridge change?
Apr 11, 2008 | Brother HL-2040 Laser Printer
13 people viewed this question
k24674
jasbo
jasbo
