Question about Wine & Spirits
How do I fix a primo flavorstation co2 dispenser?
Pressing the button no longer dispenses CO2. The button has little resistance and doesn't seem to be pushing the pin far enough to open the valve on the CO2 tank. I can't get the little grey valve knob off to separate the havles of the outer casing.
Beer dispensing extremely foamy CO2 is turned down. to))0
maybe adjusting the sprinkler or pump flow
Jan 04, 2016 | Refrigerators
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
When i instert the co2 in my airmag c11 it just releses all of the co2 and its all wasted what do i do???
Take a short strip of teflon tape and put it over the end of the co2 cartridge, make sure its in straight and tighten, works good.....:)
May 03, 2011 | Crosman (4032)
Have a crossman 1077 airgun but when I put in the CO2 cartrige it empties the gas. Used very little. Is there a home remidy or send it out to fix.
I would send it of to fix, playing with compressed gas is dangerous, sound like a seal my have corroded.
Feb 13, 2010 | Crosman (4032)
Daisy CO2 200 pistol needs seals I think.
Try oiling it first. In the CO2 cartridge well, there is an oil spot. Put some 3-in-1 oil in that. If not, check out this link to see how to fix the seals on the pistol.
Oct 25, 2009 | Daisy Toys
Beer dispenser
Shut of the CO2 tank, then hit the pressure release valve on the side of the beer tap. Make sure there is a grey check valve in the tap where the red hose (co2) is connected. Also make sure the white ball in the tap where the white hose (beer line) is not stuck. You can remove this, it isnt really necessary. Once all checks out, open the tank and readjust the co2 regulator. The reading should not be more than 12 PSI. Everything should work just fine after this. Make sure the glass is as close to the faucet as possible (slanted is better) when dispensing beer. Hope this help :)
Jan 21, 2008 | Haier (HBF05EAVS) Beverage Dispenser
When the beer dispenses it has way too much head.
try adjusting your co2 pressure down a litle bit it should help
Dec 12, 2007 | Beverage-Air BEVBM23 Commercial Beverage...
Wine & Spirits Logo
106 people viewed this question
Top Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
