Question about Samsung RF4287HARS Stainless Steel French Door Refrigerator
Water dripping from freezer
After changing the water filter last week -- noticed dripping water -- checked the line -- was not water line. Dripping from the freezer area. Almost like condensation -- won't stop. Freezer seems to be keeping temperature, but continue to have a good bit of water accumulating under the unit and spilling onto the floor in front the unit. Did power freeze but did not resolve problem. Water continues to accumulate.
  • Samsung Master
  • 5,323 Answers
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 10, 2015
bbtoast
  • 319 Answers
SOURCE: Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Posted on Jan 01, 2008
sandy82
  • 10 Answers
SOURCE: WATER ON THE FLOOR UNDER FREEZER DOOR
dear jim
there is drain line get chocked up with ice.Please open freezer evaporator cover u will find there is ice blocked in drain tray,melt it with hot water,check drain heater attached to the drain tray,if defective replace it,it will work fine
regards
sandy
Posted on Jun 08, 2008
SOURCE: Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Posted on Sep 06, 2008
BIKER T
  • 909 Answers
SOURCE: Sumsung RS2556 water leaking on
You need to switch the unit off for about 14 hours with the doors open and get a complete defrost. When all is defrosted, and water is wiped up. switch on again and check after 4 hours how "Stable or unstable the temperature is" Mostly, the door is accidently left slightly ajar and before you know it, frost blocks the evaporator then bad cooling is experienced. Remember to dry the water that would have collected in the tray on top of or next to the compressor. If it does not improve, call a technician as more complex testing is required looking for the defective component/s.
Posted on Aug 15, 2010
  • 796 Answers
SOURCE: samsung refrigerator leaves puddles of water on the floor
it may be level but the floor may be uneven. find the lowest corner of the fridge, where it is lower than the door. Put some coins under the foot at that corner, does it make the door more aligned?
Posted on Dec 16, 2013
Water dripping in refrigerator from ice forming in top rear of refrigerator. Ice has formed below what we think is the automatic defroster and is dripping water into the the main part of the refrigerator....
You have a drain clogged at the bottom of the evaporator inside freezer compartment. You'll need to remove all contents put towel inside, turn off, pull out to access back of fridge, pull drain line off or check at bottom in pan where it normally drains, you can melt ice at top of tube with hot water,hence the towells. this is a messy job usually takes about a good hour to get it right, just perservere. I will fix it, when you get it cleared. I have employed a coat hanger to speed things along as a tech it is the call I dread because of the mess.
Good Luck,Masta tech
Aug 21, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer...
The drain heater goes into the drain,not outside it.
You need a longer drain probe to push all the way through the drain.
Look underneath for a kink in the drain tube.
Feb 06, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
New fridge, water in freezer
is there only light frost on the back wall??
Sep 28, 2007 | KitchenAid Architect KBFA20ERSS Stainless...
Samsung RF4287HARS Stainless Steel French Door Refrigerator Logo
66 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
