My frigidaire washing mashine model ftw3011kwo has a broken lid latch and won't work wout the lid latched how can I get around that?
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
micromend
  • 748 Answers
SOURCE: Dell laptop lid latch problem
The spring and latch are available from Dell but this is a very hard repair. I do this for a living and screen repair is always a challenge. If you want to tackle it then call Dell first to get the parts. Once the parts have arrived put the laptop on a non static mat (placemats work well). Take out the battery and do not connect the AC power. If you're lucky on your screen there should be four rubber bumpers. Peal these off and there should be a screw behind each one. Now the bezel has to be unlocked from the back. You'll need a couple of plastic pry devices. I like to use plastic bike tire irons. Once the bezel is off you'll see the catch and where the sping goes. Make sure you find that old spring, you don't want it ending up in the electronics. Now just reverse everything to put it back together. You'll need to put a little rubber cement to put on those bumpers. If you're machine doesn't have the screws you'll have to use those plastic tire irons to pry apart the screen. Be careful and don't force it.
Posted on Jan 05, 2009
  • 82 Answers
SOURCE: maytag quiet series 300 - model MDBH970AWW door
remove the inner door panel and control cover, switch will pop out after that
Posted on Jul 17, 2009
SOURCE: 2002 camry - Need to replace broken console lid
Solved it. Found a small shank screwdriver that fitted into the opening with a little bending of the plastic frame. managed to replace it with a new one without trouble. No further help needed. dave
Posted on Nov 09, 2009
My affinity washer door wont close. Seems the door lock is not working or something is stopping the door from latching
you may have broken off a piece of the latch
(hook portion) either on the door or the receiver portion on the machine. check for diagrams online using model #
Apr 04, 2016 | Frigidaire Affinity FAFW3577KW 3.5 Cu. Ft....
Want to bypass my lid lock on my washer. since a part is broken and my apartment maintenance guys will take 3 months to get here to even look at it for me
try jamming an old sock in the latch hole , I do remember a lady who's kid did that so he could watch the stuff go round an round inside, it kept the lid from latching , of course that was why I got a call to look at it (safety around small children and all ), so I removed the sock bits and then latch worked again
Jan 23, 2016 | Washing Machines
Frigidaire affinity model number FAHE1011MW wont lock lid and wont come on. Cant afford new machine how can i troubleshoot this problem
I appreciate your inquiry, Martha!
I understand that your Frigidaire washing machine will not lock the lid and will not operate. If the lid will not lock then your washing machine will not communicate to start the load. This however could be an issue with your lid strike, latch, or control panel. I would recommend checking to make sure there is no visible damage on the door strike or latch. This could also be an issue with the continuity of each component and in order to check that you would need to disassemble your washer. This is not a simple DIY job. I would recommend having a professional technician out to perform proper repairs. Having a technician out will prevent any unnecessary part purchases. I hope this information is helpful for you. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
Model ftw3011kwo washing machine won't work after breaking locking lid piece
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
Dec 14, 2014 | Frigidaire Washing Machines
Replacing lock and latch on my frigidaire affinity washer
Error code 41 is about the door not latching. Appliancepartspros.com has the parts you need. Just enter your model #.
Jul 06, 2014 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer modle ftw3011kwo
Do you notice any beeping, flashing, or error codes? You could have a bad lid switch, door latch or even a timer. A professional would need to diagnose the unit if no error code is appearing.
Aug 02, 2012 | Washing Machines
Frigidaire Stackable model #FEX831CSO door won't open
Unplug the machine and where the lid is latched you can push a piece of wire wire in the same hole it latches through. The wire will bottom out after in the hole about a inch. Push it slightly farther and try raising lid as your pushing. All the lock is is a metal tab that pushes up and down. After time the enclosure it's attached to splits and makes it fail but it can be opened with whatever goes farther in that hole then the latch itself.
Jun 16, 2012 | Frigidaire FGX831CS Top Load Stacked...
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
