Brother MFC 210C All-In-One InkJet Printer Logo
Posted on Nov 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copy picture how do you copy pictures from a memory card when you put it in the slot?
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on Nov 04, 2007
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
557852
Points
2204
Copy on paper (print a picture) or copy to computer?
Frist thing simply press photo cap and start color ply watch the display!)
Second issue: you need the mfl-pro suite software installed. Windows: Press START/PROG./BROTHER/CONTROL CENTER. Here you can choose the photo cap in diffrent modes.
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
2answers
How do i down load pictures from my cannon camera memory card
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
1helpful
How to import pitcures using an sd card on acer laptop
you should be able to use windows explorer to find the memory card - it will be listed as another drive on the PC - most cameras will save the images into sub directories on the memory card - depending on how many images are save you may have multiple sub-directories. you should then be able to copy the images off the card onto the PC. goto Start>computer and see if you have the card listed - even without a card inserted, you should see the drives - possible called - SD/MMC and or memory stick - depending on what memory slots you have
I can't find my install cd and I can't get pics off of my old phone onto my computer, help! These are valuable since I took pictures of President Barack Obama when he was campaigning in Texas. I really...
hi,
does your phone have a memory card?
if yes, do these..
>>if the pictures is stored in your phone memory, then copy the pictures from your phone memory to your memory card. once copied, switch off your phone, remove your memory card, get your memory card adapter, insert memory card and insert it to your laptop sd reader slot and copy the files from your memory card to your laptop. if you use desktop and has no sd memory card reader slot, borrow memory card reader from a friend, connect it your computer, insert the your memory card from there and once read, copy the files to your computer. this also is applicable if you want to copy files from your computer to your phone.
>>if it doesn't have, then, borrow a bluetooth dongle from a friend, pair it with your phone, and send the file from your phone, one after the other...
good luck..
2answers
I have alot of photos in my pc and wanted to put this 2gb card and get them on there
put the microSD into a micro SD adapter and plug the adapter into the SD slot on your PC the folder will open and you can drag photos from your photo folder into the SD folder
Motorola V360 -Memory card slot error
Hai Dud,
Are you using Micro SD transflsh memory??
Format the Card on the PC using FAT, after that use a CARDREADER and put these folders on the card: MOBILE and in the mobile folder put audio, video, kjava, picture, temp! Shutdown your Motorola, remove the backcover and plug-in the card! After that Start Your Motorola and copy a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
2helpful
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
1helpful
How do I transfer pictures "from" my computer "to" my Scan Disc?
Some computers have a card slot built in the front of there case,if not, you need a usb card reader. They are very cheap. You put the card into the reader,plug the reader into a usb port and windows
will open the card as a folder. It is used just like a hard drive, you can copy and paste or just drag something into the folder that is
your sd card.
http://www.walmart.com/catalog/product.do?product_id=10038332
You can also get a reader that can handle several different kinds of cards.
18helpful
Getting pictures off internal memory
1....put your SD card in the slot...
2...turn cam on and go to playback menu
3....go to MENU/OK option
4...scroll down to COPY select ok
5....Then choose option INTERNAL memory to card and hit ok
Transfer pictures to memory card
You should just transfer the pictures to your computer (Then back to the card if you want). I don't think there is a copy to card function. However, internal memory and card memory are separate, so there's no risk of overwriting them, either. Just don't delete them.
Norman Weimar
Norman Weimar
k24674
