Question about Canon PowerShot A75 Digital Camera
Will fuji fix ccd? - Canon PowerShot A75 Digital Camera
How can i fix my Fuji film F470 camera- i dropped it and now pictures have horizontal lines on image after picture is taken
The problem you are experiencing at the moment, is a typical result of a CCD which have blown. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's likely a CCD issue and it's no wonder that it will be more expensive than buying a new digicam. This is why you need to be exceptionally careful when taking care of your camera since most are uber sensitive to being damaged by the slightest miss-handling.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own. Check this links that could give you additiona details:
- imaging-resource.com/badccds
- Powershot-S1-CCD-Problem
Hope this helps (remember to rate and comment this answer)..
May 13, 2011 | Fuji FinePix F470 Digital Camera
Get fuji fix products with faulty sensors like Canon did? http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=9824
Actually, it was Sony. But yes, they do. Your model A310 is not amongst the models with the potential fragile CCD. Other physical thing can cause the CCD to fail. Moist, impact to mention some.
Mar 26, 2010 | Fuji FinePix A310 Digital Camera
When looking at view finder shows multip;e colors and blur image
Most likely dead CCD. Steve5's solution to question by w_donaldson5 was:
The CCD is dead. Google "defective CCD fuji" for technical explanation and what to do next.
Mar 12, 2010 | Fuji FinePix S5000 Digital Camera
Fuji finepix s5000 digital camera
Your CCD sensor has failed. Common digital problem that uses Sony sourced CCD chips. Proffesional factory replacement of CCD is only fix or buy another physicaly damaged unit and swap CCD boards. Not hard but intricate and time consuming.
Oct 07, 2008 | Fuji FinePix S5000 Digital Camera
Fine pix fuji S5000
Motherboard is dead, and it costs much to take it to the repair shop. It doesn't pay off, for that amount of money you can buy a better camera. I'm trying to find a web shop and to check the price, so i could repair it myself, but had no luck finding it so far. Anyone?
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Fuji s20 pro failed ccd, where can i get a replacement ccd from? how much would it cost regards steve Hi, I think I'm having the same issue as well. Just getting the snowstorm on the screen. Still takes...
I had the same problem - called Fuji in UK, they denied all responsibility. Had a rethink, checked on the web, and then called them back with the following -
Fuji USA and Canada both fix this problem under warranty
S2 pro and S700 both on their recall list for failed CCD's and the S20 pro uses the same CCD so why won't they fix it?
Lots of apologies and they fixed it for free!
Jul 30, 2008 | Fuji FinePix S20 Pro Digital Camera
SPARE PARTS FOR FUJI FINEPIX S7000
Fixya is unable to recommend parts sources.
Jul 22, 2017 | Fuji FinePix S20 Pro Digital Camera
Purple screen
It appears your camera has a bad image sensor (CCD). Based on the model, it should still be under warranty. This is a warranty issue, that Fuji should look after. There is nothing you can do, yourself, to fix it. Even out of warranty, Fuji fixes many of these, as they acknowledge that the sensors were improperly manufactured. Take your camera and proof-of-purchase paperwork to the place of purchase, or directly to Fuji's national supplier.
Jun 09, 2008 | Fuji FinePix Z10fd Digital Camera
A little research shows me that Fuji has undergone an extensive repair recall for several Fuji models because of failed CCDs. My S20 Pro just lost it's ccd as well. For some reason it looks like the S20 was not covered in the free repair offer by Fuji. Has anyone else had a CCD problem with their S20
Jan 30, 2008 | Cameras
My F410 ceased to take photos
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Nov 02, 2007 | Fuji FinePix F410 Digital Camera
Canon PowerShot A75 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
