Question about Seagate FreeAgent Computers & Internet
Seagate freeagent desktop 9nk2-al510
Powers up and lights on but do not see on my computer
  • Seagate Master
  • 3,368 Answers
It varies depending on the operating system. You can create a Linux mint DVD and boot that without installing. It will take a moment as it is reading the OS from the DVD then see if you can see it, if so it is OK, if not something is bad or set wrong in the USB hardware system.
Posted on Jan 07, 2017
SOURCE: Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Posted on Feb 03, 2008
  • 3 Answers
SOURCE: Seagate FreeAgent Pro Desktop 250GB - no power
Hey, I had what might be a similar problem, drive would have power but wouldn't spin up properly or show up in my computer. Don't think there is a long term fix but I posted on my site how I got all 250Gb of the data of it, hope this helps, it's http://www.moneywhatmoney.co.uk/index.php/Bens-Articles/Seagate-from-the-Ashes.html
Posted on Jun 06, 2008
SOURCE: No Power to my Seagate FreeAgent Pro 500GB
HI I AM SHAHBAZ GILL FROM GREECE ..I HAVE PROBLEM FOR THIS .PLZZ HELP ME................ Seagate free agent desktop 500 gb........ directory is corruted ..
Posted on Oct 05, 2008
mbase213
  • 728 Answers
SOURCE: seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Posted on Jan 04, 2009
  • 12 Answers
I have a seagate freeagent pro 320 gb. worked fine for over a year. all of a sudden no power at all. Plugged it into my 12v dc adapter from a western digital external HD and it works fine . I am calling Seagate tomorrow for a replacement plug.
Posted on Feb 22, 2009
How do I work on my data on the Seagate FreeAgent 2TB GoFlex Desktop USB 2.0 Hard Drive as my computer memory is at capacity. I want to be able to use my external hard drive as an extension of my computer...
Assuming you are using a Windows operating system, you can just plug it into your computer's USB ports, and the computer will recognise it as another hard drive.
Instructions:
Double-click on 'My Computer' and take note of what drive letters are there (C:, D:, etc.) before you plug in the Seagate Freeagent.
Plug in the Seagate Freeagent. You'll see the new drive, likely E: or F: (depending on what is already there before you plugged in the Seagate Freeagent)
Double-click on the new drive, and it'll open up and you'll see the files stored on that drive. You can drag and drop files and save to this drive like any other folder on your computer.
Mar 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
How do i find the files that have been saved on my seagate freeagant goflex desk 2TB drive
Hi there babyface,
You just have to plugin your Seagate FreeAgent to your computer's usb port using the usb cable. Once plugged in power the seagate on and your computer should pop up a notification, usually in the lower right corner of your computer screen, saying that it has detected a new USB device. Next, right click your Windows Start button and choose Explore to Open Windows Explorer. Once the window opens, look for the drive letter associated with your Seagate FreeAgent under "My Computer" or "Computer" located on the left pane. Click for that drive to show the contents on the right side of the window. Thats it!
If you need further assistance, please let me know. Thank you for using FixYa.
Jan 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
The light on my Seagate freeagent go flashes quickly when it is connected to my computer, indicating an error. What should i do?
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Jul 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Seagate 250GB FreeAgent USB 2.0 Ext Hard Drive with laptop
Whether your computer is a laptop or desktop does not inherently decide if the drive will work or not. If it can't see the connection, there must be another problem with the drive. I would suggest reporting what you have done to try and make it work and anything you notice out of the ordinary (how lights on the drive are acting, noises the drive is making, alerts you see when you plug it into your laptop, etc). That will allow us to better help you find a solution to the problem.
Feb 19, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Jun 03, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
64 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
