Question about Sharp Televison & Video
Locate flyback transformer
I need to know the voltage for the flayback in a sharp 21M-FG1L. Thanks, Miguel milesbrecker@yahoo.com
techman
  • 3130 Answers
SOURCE: Hitachi Multisystem TV model # C2980FS ..not powering on
First off you gotta tell us whats the right model and make as you have two listed here and both of these flybacks are avail. trough http://www.partstore.com. The parts are not listed online but get the toll free # or leave a message for them to get back to you. Now A flyback is not a user replaceable part for starters. It is soldered in and theres very high voltage inside these sets even after they are unplugged, and its not adviseable to replace a hi-voltage part in a set, unless you know the issues involved with replacing such parts. Good Luck
Posted on Jun 17, 2006
SOURCE: Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Posted on Sep 11, 2007
sharcnet
  • 2130 Answers
SOURCE: Toshiba flyback transformer
Try MCM Electronics. Try this link:
http://www.mcminone.com/search.asp?keyword=flyback
You can also call them at: 1-800-543-4330 They may be able to help you find the one you are looking for or offer a substitute.
When I owned a repair center several years ago, I ordered flybacks and other parts from them and never had a problem.
Good Luck!
- Jim
Posted on Jan 22, 2008
SOURCE: flyback transformer on television
does anyone know here the flyback number of sanyo tv model DS25390, chassis#: 25390-02...tnx!
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: FLYBACK Transformer for APex 32'' Model #PF3230 Flat Part #BSC 70Y
If the image is stretched, the HV output from the fbt is too low. You may have a bad H-out transistor which feeds the transformer. In the electronic service repair industry, its always a very good idea to replace this transistor with any flyback change.
Posted on Apr 24, 2009
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 21, 2014 | Sharp Televison & Video
Howb to test for bad tv flayback transformer
If and this depends on brand and model number, the output transistor is shorted confirm the voltage from it to the transformer and if being held down or High voltage only comes up to 5 or 6 thousand volts the flyback is suspect.
Most shops of course have a ringer which will with part out of set test the primary winding (one that goes to and from the sweep transistor).
Some models are more prone to bad transformer than others so look at the history of this brand/model.
A bad one will usually take the sweep transistor out sometimes repeatedly--but other issues in for example the driver circuit in some models will cause the transistor to pull excessive current and get hot very fast---not usually the transformer.
Aug 28, 2012 | Televison & Video
Sharp tv 29" model#29l-fg1l. made from malaysia . the tv standy red light blinking from red to green when press on.nothing yes. what " s be ? please solve my problem?
Dear sir/Madam,
Check power supply(SMPS) section.Check/replace all electrolytic capacitor without power capacitor and resoldaring power supply section after then check horizontal output transistor.
thanking you
uttam
uttam_bm@yahoo.com
Sep 20, 2010 | Sharp Televison & Video
NO POWER rca hdtv R52WH74YX61
if the fuse you took out at first was fried black as cool, how do you know it was .6a
now the fl231 as I told you before is close to the flyback transformer
Go to google search -type in flyback transformer --enter
scroll down to get video results for flyback
click on the picture
now you will see what a flyback looks like
you should not try to fix tv if you have no idea of tv repair.it is very cmplicated and fatal .there is serious high voltage in tv sets
Nov 23, 2008 | Televison & Video
Hyundai 14" colored tv no power
if the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Oct 17, 2008 | Sharp 25R-S100 25" TV
My tv cant turn on
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
May 26, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Picture stretched on CRT 32"
the problem is that your flyback and also your power supply circuit. check the B+ of your supply.
Apr 24, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
