Why acid base reaction ofton called proton tranfer reactions
SOURCE: Set up
I can not set up my DVD, no reaction to remote control, no reaction manual bottons.
Can you help me?
Thanx
Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
Posted on Aug 05, 2008
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
  • 8 Answers
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Posted on Mar 03, 2009
  • 5 Answers
SOURCE: power switch light,won't go off
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
raycalo
  • 358 Answers
SOURCE: time delay between pressing remote and reaction on screen
stevec795
Do you have fresh batteries in the remote? Drained batteries can cause the delay problem. If you do have fresh batteries, then you will need to readdress the remote to the receiver. I have provided instructions on readdressing the remote. I hope this helps.
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Posted on Feb 02, 2011
What is the real meaning of light dependent reaction? Explain what it is? Please.
light reaction (redirected from Light-dependent reaction)
Also found in: Thesaurus, Medical, Encyclopedia, Wikipedia. light reaction n. Any of the chemical reactions that take place as part of the first stage of photosynthesis and require the presence of light, by which energy captured from light is converted to chemical energy in the form of ATP. American Heritage® Dictionary of the English Language, Fifth Edition. Copyright © 2011 by Houghton Mifflin Harcourt Publishing Company. Published by Houghton Mifflin Harcourt Publishing Company. All rights reserved. light reaction n (Botany) botany the stage of photosynthesis during which light energy is absorbed by chlorophyll and transformed into chemical energy stored in ATP. Compare dark reaction Collins English Dictionary - Complete and Unabridged, 12th Edition 2014 © HarperCollins Publishers 1991, 1994, 1998, 2000, 2003, 2006, 2007, 2009, 2011, 2014
Light dependent reactions
Apr 28, 2016 | Cars & Trucks
What is the chemical reaction that take place in the lead acid battery?
the sulphuric acid reacts with the lead in the plates with the result that the acid breaks down and tends to go water and the lead becomes lead sulphate
when a battery is dead flat, the plates are all lead sulphate and the density of the acid is approaching that of water
that can be tested with a hydrometer
When a charge is applied to the battery terminals , the process is reversed and the lead sulphate returns as lead and the water ( low ph acid) returns to sulphuric acid
Mar 05, 2016 | Cars & Trucks
If a reaction absorbs 40K.J of energy,what is deltaH of this reaction
Energy absorbed by reaction mean the reaction is endothermic. If the reaction is endothermic the change in enthalpy is positive. Delta H is +40 kJ
Oct 07, 2013 | Office Depot Elementary school Physical...
Which is the plant-based milk least likely to cause allergic reactions?
Plant-based milk, being a substitute of dairy animal milk, prevents allergic subjects from having milk-related allergic reactions. Therefore the only risk of allergic reaction would be if the subject is allergic to the specific plant that the milk was produced from. For example a celiac person will probably have allergic reactions to any plant-based milk that comes from grains
Jul 03, 2013 | Wine & Spirits
How do you know when an allergic reaction needs you to call an ambulance or go to the hospital?
A mild but still uncomfortable allergic reaction might involve hives, itching, watery eyes etc. For these symptoms you can get an over the counter anti histamine or eye drops.
But if an allergic reaction involves difficulty breathing, tightness in the throat or any other signs of a severe allergic reaction, medical help should be called immediately.
Feb 28, 2013 | Health & Beauty
What does pH stand for?
the p stands for potential and the H stands for Hydrogen, and it refers to the ability to attract hydrogen ions.
Jan 28, 2013 | Measuring Tools & Sensors
How carboxylic acid different from mineral acid from ionization point of view
  • A mineral acid is defined as a water-soluble acid derived from inorganic minerals by chemical reaction as opposed to organic acids (e.g. acetic acid, formic acid).
  • Specifically: When you put sulfuric acid (H2SO4) into water, all of the molecules of acid will dissociate into two protons (H+) and sulfate anions (SO4 -2). There will be no intact molecules of H2SO4 in solution. When you put acetic acid (CH3COOH) into water, only some of the molecules dissociate into proton (H+) and acetate anions (CH3COO-). Some of the acetic acid molecules remain intact in solution.
  1. - Mineral acids are inorganic derivatives while carboxylic acid is a organic compound.
  2. - Mineral acids dissociate completely into ions while carboxylic acid dissociate partially.
  3. - Mineral acids show high conductivity while carboxylic acid shows low conductivity.
  4. - Mineral acids shows negligible in ionization on increasing the temperature while ionization of carboxylic acid increases with the increase of temperature.
Jan 02, 2011 | Computers & Internet
Soduim + iodine
i think its 7...
"7.) calcium oxide + diphosphorus decaoxide"
that causes the problem - stop drinking it with empty stomach...
Oct 10, 2009 | MPS Multimedia QuickStudy Chemistry for PC
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
